- May 6, 2005
- 2
- 0
- 0
i can use a few minutes of advice if u have some free time. i have an 85 gt ,5 speed. engine is knocking.
i have a parts car 1995 gt with a 5.0.i bought it 2 years ago with intentions on using the motor one day.
i was planning on converting my car to a efi but am realising it will turn into a horrible project. my car now has a aftermarket electronic kind of distributor that works fine... and basically stripped of all antipolution stuff... has a nice new edlebroke carb and still has the original intake.
all the rest is original.
do you think i can take the 1995 mustang 5.0 and strip it down ,keep just the block and heads.... then use my intake and carb,headers,distributor etc... put it back in ? is it the same block and heads to receive these parts ?
2nd option : i have an old lincoln lsc 1992 with low miles but all rusted out. 5.0 ho as well.... i was trying to keep that car as i use it... but if the 1995 5.0 is not doable on my 85 gt, i will use the lsc motor if i can use the block to fit all my 85 gt parts on it and put it back in...
basically, i am looking for the easiest way to get my gt back on the road using thel 1995 gt 5.0 ho block or the lsc if i have to...
also, i want to keep the block and heads from the efi motors as my heads are shot and need full rebuild on the 85 gt .
unless someone thinks i can do the swap and keep the efi... if the 1995 gt has all that i need... i can do some work, i am well equipped... if it means i need to run a return line for fuel... i am sure in the 85 gt, there we return lines ? i have the complete car so i can take the cu,harness,all that is needed... but how do i connect the harness to my 1985 gt car ? i am not sure if it will need modifications..or a new harness.... i would love the efi in the 85 gt.... but dont want to find myself haveing to go out and spend lots of $ on parts...i have fuel pumps for efi, boschs,all the hoses... from all projects i do with other cars... but i guess i never did anyything like this..so am a little worried... easy would be the carb original setup using the 95 gt block/heads..if it fits using my complete engine accessories and would it run
please give me some advice...
