Also figured out a solution to the sway bar interference. I bought some steel bar to extend the sway bar, then my buddy suggested just making drop mounts. I went for the drop mounts.
Before
After
Before
After
I have an AC delete pulley on the shelf, will never use it again. PM me if interested
When I initially took out my crossmember, I noted the direction it was facing (they’re actually marked as well) and I tried to put it in the same way. My old trans was out of a 2001 v6 car which was modified to work with a 96 and a 5.0.So what was the problem with the crossmember?
It would be nice to tuck it into the fender well but the pro m filter is a big son of a bitch lol. I didn’t want to hack that much out of the wall just yet. Later on I may do some sort of air box for it. For now, The performance difference is somewhat negligible.That look bad azz, I would like to see that air filter moved outside the engine compartment or at least shielded from the heat.
nice job!
