First of all if you think you overcharged it then you need to release some to get it between 25-45 lbs. so get a gauge to check the pressure. You can get gauge from your local auto parts store. You have to test the pressure of the system with the AC running so in order to get the AC compressor to kick on you will need to install a jumber on the AC cycling switch harness (see how below)
But aside from that, I guarantee it's you AC Cycling Switch. Here's how you test it. Look on the passenger side firewall and you will see the receiver/dryer. On top of it is a twist on switch with an electrical connector. Unplug the electrical connector and install a jumper wire on the electrical connector and then turn on the AC and the AC clutch will kick on. If the AC clutch kicks on then most likely the AC Cycling Switch is bad. Now, the Ford Service Manual states to check the pressure of the system if the above happens and if the pressure is ok, replace the switch. To check the pressure, you need a R134a manifold gauge or you can use one of those recharge kits from you local parts store with the gauge to check the pressure. But again, I guarantee its the AC Cycling switch, which cost me about $33.
This was the first part I replaced on my new 95 Mustang (I was out of the warranty mileage) in the summer of 1996 after I had just purchased the Ford Service Manual so the book's step by step diagnostics paid for the book.
If your AC was working with no problems, such as the AC clutch was not cycling on and off, then most likely it's just the switch.
Now, if your AC clutch was cycling on and off constantly before the AC quit, then your system is low and needs a recharge, which could indicate a possilbe leak in the system. But you indicated that you charge (maybe overcharged) the sytem so again I think it's the switch
Peace
