Hey everyone
Looking at a 5.0L 302 in the next couple of days and the seller tells me the motor has the following addons:
.030 over
has hypertec pistons balanced assembly
Has ARP main studs
HV Melling oil pump
E7TZ heads with exhaust ports cleaned
performer intake 600 Holley carb
M6250 A311 cam Ford Motorsports 472/447 lift
10.5 compression
MSD
what do you guys think. Is this a mild build? Dont know much about the a311 cam? It's also carbureted which I dont want. Can I install a trick flow upper and lower in its place? Is it worth considering.
.030 over
Has ARP main studs
HV Melling oil pump
10.5 compression
MSD
