Camber adjustment w/ stock stuff
Foxslider
im not that much of a idiot
Oct 25, 2019
421
116
53
33
Houston, TX
My camber is too positive. Wondering if i can adjust it with the stock plate. Right now they are set at maximum out or towarda fenders. So i was gonna loosen em up and slide it in to the middle. But the slot is kinda radiused so im thinkn its gonna throw the toe way off. I then adjust toe by tierods huh?
Suppose i could just buy some MM cc plates and be done. And i prob
Will. Was going to wait and do it with my coilovers. But i need to fix it now before i put good tires on front. They wore bigly on outside (cord started showing) while inside of tire was still same condition as when i got it.
  • Sponsors(?)
revhead347
Just rub Vaseline all over
8,380
1,199
214
40
Acworth, GA
There are a few different methods. Your circumstance is not uncommon. There aren't too many of these cars left that haven't been wrecked, or at least hit a curb hard enough to bend the body a little bit. You can pull the strut mount down, and rotate it to see if that helps. You can also drill the holes in the shock tower a little bigger to allow some more adjustment.
Kurt
90sickfox
I didn't really have an issue with the stink...
SN Certified Technician
Mar 2, 2015
5,163
4,255
203
42
The original plates were adjusted by drilling out the rivet, jacking both sides of the car off the ground, loosen nuts, move plate, tighten, let vehicle down, and adjust toe.
There are also camber bolts that replace one of the strut bolts to get correct camber. They are a lot easier to deal with.
90sickfox
Mar 2, 2015
5,163
4,255
203
42
In all due respect. Caster is basically non adjustable without caster camber plates. It would be better to get aftermarket plates so you can get all the adjustments you may need. With aftermarket plates modifying the strut tower usually isn't needed. My UPR plates bolted on my 89 and 88 without issues.
Reactions: Foxslider
Foxslider
Oct 25, 2019
421
116
53
33
Houston, TX
Right on. I'll just get the CC's. Being stupid here.
Ima guess needing all the caster on these cars means push shock back towards firewall.
Mustang5L5
i'm familiar with penetration
Mod Dude
Feb 18, 2001
33,274
9,577
224
Massachusetts
That's how mine is set.
Full caster to the firewall, 1 degree negative camber, 1/16" toe in.
With the SN95 steering rack, it's a nice heavy feeling on the highway. I like it.
My Maximum motorsports plates were easy to install and no modification to the strut tower is needed
Reactions: General karthief
Foxslider
Oct 25, 2019
421
116
53
33
Houston, TX
Nice. I'll prob. Be like i shoulda done this sooner. + Gives me something to buy on black friday.
How do you check/set toe? I think drifters run toe out to help self steer. I think, not sure.
Mustang5L5
Mod Dude
Feb 18, 2001
33,274
9,577
224
Massachusetts
Toe out will make the car very twitchy and easy to turn. Toe straight ahead or 1/16" in will provide a more stable straight feel with a slower turn-in.
There are tools available that you can buy to do this in your driveway. Some home-depot 12" square tiles to level the car, a little salt thrown between them up front to act as turn plates, and a nice camber and toe gauge. Caster gauges tend to be a little more expensive.
It also depends on your skill level. I do my own home alignments on the Mustang mostly because I can't find a shop that will do custom specs. I spent maybe d $300 in tools and a lot of time spent perfecting my technique.
Foxslider
Oct 25, 2019
421
116
53
33
Houston, TX
Ah i see. Cool! Pretty much what i'll need to do if i wanna get my specs dialed. I'll research it. I might eyeball stuff, drive repeat till i like it. Kind of a pain. But iono.
And you set toe via tierods right?
Thread starter Similar threads Forum Replies Date
echo7 2015 GT Stock Front Camber Adjustment Possible? 2015+ Specific Tech 5
C Adjusting Camber? 2010 - 2014 Specific Tech 0
ojgrape Camber Adjustment Questions SN95 4.6L Mustang Tech 2
D Eibach Pro Alignment Camber Adjustment Bolts For 2013 Gt 2010 - 2014 Specific Tech 0
'69 Hardtop Camber Plates vs. Camber Adjustment Bolts 2005 - 2009 Specific Tech 13
SScott Can't adjust out enough camber... Fox 5.0 Mustang Tech 13
P camber adjustment 1994 - 1995 Specific Tech 5
S qa1 camber adjuster help 2005 - 2009 Specific Tech 4
mrvax Castor and Camber Adjust Plates SN95 4.6L Mustang Tech 34
gnat Adjusted my caster&camber - questions + **pics** SN95 4.6L Mustang Tech 5
bigcat Adjustable Upper Camber Plates Install 2005 - 2009 Specific Tech 3
M Camber Adjustment SN95 4.6L Mustang Tech 4
todd4566 Camber Adjustments 1996 - 2004 SN95 Mustang -General/Talk- 12
JChalfan Eccentric bolts to adjust camber?? Fox 5.0 Mustang Tech 4
wht93gtEd Caster / camber plate strut height adjustment Fox 5.0 Mustang Tech 4
cardude anyone use a vario-centric camber adjuster on 66... any tips?? Classic Mustang Specific Tech 2
dastang2 i am getting 2 inch drop springs, is there a way to adjust camber Fox 5.0 Mustang Tech 3
E camber adjusting SN95 4.6L Mustang Tech 5
S Must. Adjust. Camber. Or. Die. (Adjustment Questions) Classic Mustang Specific Tech 11
95/5.0stang pics of new rims, camber adjustment and new sportlines 1994 - 1995 Specific Tech 3
Marine One Camber Plates/Adjusters SVT Tech Forum 2
Marine One Camber Plates/Adjusters SVT Tech Forum 3
Marine One Camber Plates/Adjusters SN95 4.6L Mustang Tech 1
BlackFox5.0 How to adjust camber? 1994 - 1995 Specific Tech 9
L WTB/Trade Camber/Caster pates for 2002 Gt Suspension Parts 0
A Suspension Camber kit options for 91 GT Fox 5.0 Mustang Tech 0
A Suspension Question on Camber Kit for 1991 LX 5.0L Fox 5.0 Mustang Tech 2
H Suspension Alignment-Caster Camber Plate Question Fox 5.0 Mustang Tech 12
Noobz347 Contest J&M Engineering Caster/Camber Plate Contest Giveaway! Voting Until 11:PM EST Friday Night 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 45
K Upper Rear Camber (broke subframe holder) please help 2015+ (S550) Mustang -General/Talk 0
R caster camber plates help 1996 - 2004 SN95 Mustang -General/Talk- 2
wiseguyk Suspension Swapping Steeda for MM caster camber plates - tip to retain alignment? Fox 5.0 Mustang Tech 7
868 SOLD SVE Mustang Coilover Kit 79-93 Suspension Parts 5
Sweetmarie66 66 front end camber 1965 - 1973 Classic Mustangs -General/Talk- 2
T Negative Camber SN95 4.6L Mustang Tech 3
Nick Bos Camber Keeps Readjusting Itself... 1965 - 1973 Classic Mustangs -General/Talk- 13
a91what Camber Plates For Coilovers Fox 5.0 Mustang Tech 9
skiwesser11 Which Caster/camber Plates. Fox 5.0 Mustang Tech 5
Z Negative Camber Issue 1994 - 1995 Specific Tech 3
Evan9 Camber(s) The Welcome Wagon 14
j0rd4n Rear Camber Issue Fox 5.0 Mustang Tech 20
P Question On Lowering My 06 Gt And Caster Camber Plate... 2005 - 2014 S-197 Mustang -General/Talk- 3
MRaburn Contest J&m Products Fox Body Caster Camber Plate Giveaway 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 41
J Suspension Camber Bolts. SN95 4.6L Mustang Tech 5
J Expired Mcs Coilovers, Sway Bars And More Suspension Parts 1
nickpic Cater Camber Plates For Lowered Fox ?'s Fox 5.0 Mustang Tech 20
lil03v6mustang 2003 V6 Caster Camber Plates 1996 - 2004 SN95 Mustang -General/Talk- 1
1 Camber Kit Fox 5.0 Mustang Tech 6
illwood Expired Caster Camber Plates, Cobra Control Arms Suspension Parts 1
B Caster Camber Plates... Help? Fox 5.0 Mustang Tech 7
