when i shift into 3rd alot of the time it will kick the shifter out of 3rd. but only 3rd. the car only has 19000 miles on it and it has a pro 5.0 shifter.
No, the 3650 has them built in, the t-45 does not. Remove them for a 3650 car. And BTW the original poster needs to adjust his shift stops out more.stangGT97 said:if you installed stops on your shifter, remove them - the T-45 has stops built in already. An improperly adjusted stop could be the easy fix for this problem.
Venom_Nitrous said:No, the 3650 has them built in, the t-45 does not. Remove them for a 3650 car. And BTW the original poster needs to adjust his shift stops out more.
romgolferman said:i thought it was the stops too but i adjusted them out and it wasnt it. how do i check the shift fork?
SilverBullet00 said:How can you tell if you have a tremic or Borg built T-45?
svttech76 said:I think it was mid way thru 1998 model year the switch was made.. all 99-01.5 gts have the tremec T-45, 01.5- current gt's have the tremec t-3650...
JRFlurry114 said:I have the same problem but its with 4th gear... drives me nuts. i have a steeda tri-ax and all the "stops" are adjusted right. it really sux!!
