As I have posted before...
Accufab:
65 MM - 664 CFM
70 MM - 787 CFM
70 MM - 896 CFM (Race version)
75 MM - 924 CFM
75 MM - 1045 CFM (Race version)
80 MM - 1142 CFM
85 MM - 1322 CFM
90 MM - 1369 CFM
105 MM - 1550 CFM
To find a solid estimate on how many cubic feet per minute an engine can inhale, use the following formula on a 347 being spun to 6,500 RPM at 100% volumetric efficiency:
347 x 6500 x 1.0/(1728/2) = 652.633 CFM
A 302 cubic inch engine flows 524.306 CFM at 6,000 RPM with 100% VE.
A 331 cubic inch engine flows 574.653 CFM at 6,000 RPM with 100% VE.
A 347 cubic inch engine flows 602.431 CFM at 6,000 RPM with 100% VE.
A 351 cubic inch engine flows 609.375 CFM at 6,000 RPM with 100% VE.
A 393 cubic inch engine flows 682.292 CFM at 6,000 RPM with 100% VE.
A 408 cubic inch engine flows 708.333 CFM at 6,000 RPM with 100% VE.
A 427 cubic inch engine flows 741.319 CFM at 6,000 RPM with 100% VE.
Compare this to the flow numbers from the throttle bodies. I realize that an engine does not see a pressure differential of 28” all the time, but it gives a baseline to compare all the throttle bodies. As the pressure differential increases (greater than 28”), the flow increases through the throttle body. As the pressure differential decreases (less than 28”), the flow decreases. Accufab scores a 75 mm throttle body at 924 CFM at 28” and 780 CFM at 20”. So if you flow that same throttle body at 36”, it will crest over 1000 CFM for a 75 mm throttle body. However I am aware that pressure differentials to flow ratios are not linear, but the CFM will be more linear than a cylinder head, due to the throttle body being a simple straight through design, with shape and design being a minimal issue.
With the above information from Accufab's website, you can see that the aftermarket throttle bodies offered flow much more than your engine can breathe (302-347). Those CFM ratings are even given with no restrictions and of course engines all have restrictions, via our heads, cam, intake packaging. An actual running engine flows somewhere in the neighborhood of 70-90% from the factory. Some of the aftermarket throttle bodies flow two times this amount.
If you've got a throttle body that delivers 100% of the peak air requirements of your engine when the throttle plate is fully open, you have control of the air throughout 100% of the throttle position range. If you go to an oversized TB that delivers 100% of the air that your engine can consume while the throttle plate is only 60% open, you have given up usable throttle-control range for no advantage. Now I see this being a non-issue for track engines, because tip-in or throttle control is usually never thought about as a concern.
NASCAR is in the 125% VE with 358 cubic inches. They also run 750-830 CFM carburetors. Could they make more power with a larger carburetor? Very possible, but it shows you that the restriction is small, considering they are making near the 850 HP mark.
Throttle Body Blade Area:
One can figure out the area by a simple formula. Take the millimeter measurement and divide by 25.4 to get the inches across at the blade. Take that number and use it to find the area of the blade. We will use the area of a circle, which is roughly the shape of the throttle body blade and will give a good estimate.
The area of a circle is PI x radius x radius. The radius is half of the diameter of the blade or circle.
Example: 60 mm/25.4 = 2.36. 2.36/2 = 1.18. Then 3.14 x 1.18 x 1.18 = 4.38” (squared).
58 mm - 4.09”
60 mm - 4.38”
65 mm - 5.14”
70 mm - 5.96”
75 mm - 6.84”
80 mm - 7.79”
85 mm - 8.79”
90 mm - 9.86”
95 mm - 10.98”
105 mm - 13.41”
No wonder the Livernois 2000 HP drag car only runs a ~ 100 mm TB.
By the way, the intake tract (from plenum to cylinder) does not allow a straight shot into the cylinders.
First air SITS in the plenum first, and then it bounces back and forth between the higher pressure air in the plenum to the back of the intake valve several times.
Velocity is not an issue here, big or small.
Guys try to give you advice on "go big or go home" when they are having problems comprehending reality.
Also, keep in mind the intake you are working with. Many of them, just a couple inches after the throttle body, have much less area than the TB blade ( - blade thickness of .078-.080" and shaft thickness).
That is also known as a MCSA, minimum cross sectional area.
Think guys, think.
