HHStang said:
I bought one of these and couldn't get it to work. I ended up upgrading to a 220v unit that works great. Maybe it was just me though.
I'm not sure how to respond to that. What exactly did you initially buy and how did it "not work"?
I should correct (or clear up a couple things):
I should have said 120V 105A MIG Welder. The 120V 20A (input) is the required rating of the supply circuit. (Most standard outlets in your house are 120V 15A - some garage circuits may be 20A). I ran a new 20A line in my garage. The welder I have is the
Craftsman 20559 (which is no longer available) and I'm very happy with it. I got it on sale about 2 years ago for $450. This
Hobart is similar (this is just an example, you may be able to do better on price elsewhere).
The biggest difference between MIG welders, as the price goes up, is duty cycle and supply circuit requirements. Mine is small, thus only has a 20% duty cycle (which means for every 2 min. of welding, it requires 8 min. to cool off). I haven't found this to be an issue yet, since I pause frequently to inspect my work. The 230V (input) MIG welders tend to have longer duty cycles (30%-40%) which I'm sure is beneficial if you're doing this on a regular basis.
Here's a low cost
auto-darkening helmet similar to what I'm using.
I may by off on the tank/gas price. I remember having to put a deposit on the tank, since you are essentially renting it.
I really didn't want to get into a nickle and dime discussion on price though. If $100 +/- makes that much difference, then you're in the wrong hobby. I managed to get everything necessary to do decent welding, including an impressive clamp collection, for about $800.
