Hey guys, my buddy is having a problem with a conversion he is playing with for his Jeep. He has a 94 5.0 block with a 65 bellhousing. He has the 13 1/4" OD flywheel with the 10.5" clutch. The problem he is having is that the starter does not meet up with the flywheel. The flywheel needs to be about 14" OD. i need to know if there is a flywheel out there that will work with this application, or if its even possible to work the early model bellhousing with the late model block. We havent been able to find anything that works, so i turn you guys. Hopefully somebody has more knowledge about our problem and hopefully has a simple solution.
