Help! Attempting To Troubleshoot Mach 460 Front Left Tweeter Not Working.
TheFleshRocket
208
Southern Ill Annoy
Visit site
I'm trying to troubleshoot a wiring issue with the Mach 460 in my '04 Cobra. I get no sound out of the driver's side tweeter. (Swapping speakers and even the head unit doesn't help, so the problem is somewhere between the radio's harness plug and the end of the speaker wire.)
To the best I can figure, the Mach 460 head unit has four speaker outputs. However, the Mach 460 has 8 speakers (totally separate woofers and tweeters at all four corners). The woofers are powered by the amplifiers in the trunk, and disconnecting the secondary plug from the back of the head unit results in just the tweeters playing, so presumably the tweeters are powered directly from the head unit.
I tried using an ohmmeter between the head unit's harness plug and either front tweeter, and I get no continuity on any of the harness's pins. Additionally, the wires that plug into the two front tweeters are black, and black with white stripe, whereas the wires at the head unit's harness plug are all sorts of color combinations, none of which are black or black with white stripe. This means that there must be a junction somewhere between the head unit and the tweeters.
However, even if there was just a junction, I feel like I should have continuity from the speaker wires to the harness, but I don't. This suggests that there is something else in between the harness and the speaker wire ends--perhaps a powered crossover? Thing is, I can't find any sort of wiring diagram that confirms this--every wiring diagram I've seen indicates that the head unit connects directly to the tweeters with the randomly-colored wires.
Someone who knows more about this system that I do, please help. Where do the wires go between the harness and the speakers, and is there any hardware in between?
  • Sponsors(?)
Insain1
34
Cleburne, Texas
There is an amp mounted to the trans tunnel behind the head unit. I would try there. Just had similar problem only the left front tweeter was the only one working. I ended up just replacing all the factory speakers with new and rewiring it. The mach 460 stereo system is obsolete and you can't get parts anywhere anymore
Thread starter Similar threads Forum Replies Date
Keith5.0GT Lower Intake Attempt #3 Fox 5.0 Mustang Tech 5
InMyPrimeSVT Attempting to pull lower intake. Need help, pics included. Fox 5.0 Mustang Tech 22
1986LX2002 Tilt Steering need some help fixing because of attempted theft Fox 5.0 Mustang Tech 3
A Drivetrain I Need Some Flywheel help/knowledge please Fox 5.0 Mustang Tech 1
J New to the forum and looking forward to some expert help The Welcome Wagon 1
J Fox obsolete RELAY part number help 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 9
B Need Help 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
C Wiring swap Please Help 1996 - 2004 SN95 Mustang -General/Talk- 0
9 Fuel Help - Car Won't Start After Braided Fuel Line Conversion Fox 5.0 Mustang Tech 3
YadiStang 1969 mustang. Need help with door lock actuator rod 1965 - 1973 Classic Mustangs -General/Talk- 0
D Brake issues I need help figuring out what part to order 2005 - 2009 Specific Tech 1
M I need help sourcing/repairing a fender 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
D Progress Thread 2003 mustang gt Rebuild 1996 - 2004 SN95 Mustang -General/Talk- 3
N Progress Thread 1984 mustang gt350 will not start Fox 5.0 Mustang Tech 0
S Electrical Need help with unidentified wire connector on 4 cylinder LX 2.3L (N/A & Turbo) Tech 3
R 2000 mustang gt pro charger help 1996 - 2004 SN95 Mustang -General/Talk- 1
9 Fuel Help! - Fuel Line to Fuel Rail Question Fox 5.0 Mustang Tech 4
F I need some help SN95 4.6L Mustang Tech 1
A Fuel Fuel pressure help! So lost! Fox 5.0 Mustang Tech 17
W T5 rebuild - need help identifying parts Fox 5.0 Mustang Tech 12
Gman007 Need help with strut choice. SVT Tech Forum 8
markinms Engine Explorer Intake Swap Performance Issues - Need Help! Fox 5.0 Mustang Tech 10
Jetzv8 ASE Ford Mechanic knowledge & help 2015 S550 2015+ (S550) Mustang -General/Talk 4
S 2002 gt need help. 1996 - 2004 SN95 Mustang -General/Talk- 4
G Question!! potential damage to flexplate/crank during 4R70W swap SN95 4.6L Mustang Tech 1
S Help Leaking manifold 2005 - 2014 S-197 Mustang -General/Talk- 1
P Engine 94 GT 5.0 EGR help 1994 - 1995 Specific Tech 2
D 1987 4 to 8 wiring Fox 5.0 Mustang Tech 8
T Need help with throttle cable. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
Ramennoodles77 HELP! New fox owner power question 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 20
Anti_Hero0932 Electrical Mystery connector please help! Fox 5.0 Mustang Tech 3
T Engine Need help with 5.0 ho speed density build Fox 5.0 Mustang Tech 9
M Help identify these quarter scoops 2005 - 2009 Specific Tech 2
titanium1990 Electrical No spark at coil help! Fox 5.0 Mustang Tech 2
S 1995 Ford Mustang 3.8L V6 - Electrical Issues - Need Help! 1994 - 1995 Specific Tech 2
T Questions about power steering delete!! Need help!! 1996 - 2004 SN95 Mustang -General/Talk- 5
5 Powersteering Pump replacement gone wrong Fox 5.0 Mustang Tech 15
R need helpful tech help Fox 5.0 Mustang Tech 3
M Looking for clips to attach the rocker panel moldings and trim on a 1970 Mach I - any help is apprciated Classic Mustang Specific Tech 2
C Engine 88 GT donor swap help Fox 5.0 Mustang Tech 5
P WTB/Trade HELP!! Iam doing v8 swap Mustang II Parts 1
F Help needed 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 11
T HELP MY CAR IS RUNNING TERRIBLY! 1996 - 2004 SN95 Mustang -General/Talk- 1
silverlx50 Engine Help with jrichker's injector testing, more details please Fox 5.0 Mustang Tech 0
R Please Help! Ideas/Tips on how to make my '93 2.3l (NA) Convertible Faster. 2.3L (N/A & Turbo) Tech 6
A Electrical Help. I’ve about had it with this car.... Fox 5.0 Mustang Tech 12
M Electrical Little ecu wiring help, almost there! Fox 5.0 Mustang Tech 0
9 Engine HELP - Fuel Line to Fuel Rail Questions Fox 5.0 Mustang Tech 0
T Help! 1996 - 2004 SN95 Mustang -General/Talk- 1
A Tire Help 2005 - 2009 Specific Tech 1
