AutomaticWeapon
my .02...
Flowtech Xpipe if you cant find one used and cheap leave it alone! its not worth the $200 Summit sells it for. mine had to be cut apart and re-welded to fit my car properly.
Steeda Pulleys & T/A best bang for the buck you can get... short of gears. these two mods are proven to work and you'll definatily notice the difference in performance.
4.10 Gears i wish i jumped straight to 4.30s...
Drag Suspension i have Steeda Hardcore LCAs, Steeda HD UCAs, Steeda SFCs, (Fox)Lakewood 90/10s, Fox springs (4cyl fronts and V8s rears cut 3/4), Centerline Telstars, M/T ET Streets, and Removed Swaybars. if your into the 1320 like i am this type of set-up cant be beat. my beast 60' has been 1.68...
Listening to Well Informed Advice there is no pricetag for this. you have to use your head and realize who the BS'ers are and seperate yourself from them. once you learn a thing or two from experience attempt to help the peeps that are just starting out fresh.
Summary these 5 mods have gotten my ETs from low 14s to 12.83/105 in less than a years time, and there is still room for improvment as my car sits... if you are into the drags, they will work for you too.
-Mike
-Mike
