mikestang63
SN Certified Technician
Thanks bro I did check the main bearings and they're OK.diesel fuel and check the bearings
Thanks for the info, I'll order the thread repair kit. I am anxiously awaiting the Brown truck todayShould be all 1/4-20 (7/16 head) with a pair of 5/16-18 (1/2 head) on each end at the seals. Sbf's have no metric threads anywhere.
I can't wait, I'm giddy!I wish my setup looked that good....
The torque curve is going to be awesome
If you plan on running low boost on this blower then I suggest a smaller TB..... like a 75mm.Well I'm out on both of the 42# injectors now. I sent a payment for the green top Bosch injectors and the guy went to box them up and drop one of them and broke the plastic connector off of it.
Anybody have a clean set of 42# injectors?
I also need a 90mm Accufab throttle body
please PM me if you have some you want to get rid of.
What kind of boost justifies the 90mm TB? Like 14+ psi?If you plan on running low boost on this blower then I suggest a smaller TB..... like a 75mm.
Why? you ask, we'll the throttle will be very touchy with the 90mm. A 75mm will be much smoother and will support the 10 psi you are looking for.
But I have been wrong before, just going on what I have read.
There will be no MAF, I'm speed density. Maybe you meant to say TB? I only have a 70mm TB at the moment and I will not install that on this Flowzilla. So I'm in the market to buy a TB so I'm leaning toward the 90mm. I've seen the same results going from a 75mm to 90mm TB and it netted more boost and cooler air charge temps which helps produce power too. I hope it doesn't effect idle too much by going big on the TB. I have a 3.5" Anderson power pipe that'll go to a big K&N filter inside the fender.Positive displacement blowers like to have the clearest inlet tract that you can give it. With the Flowzilla inlet, you might see 1-2 lbs of difference in boost between a 75mm throttle body and a 90mm throttle body on two identical engines that are both equally capable using all the air pushed to it.
I think the 90mm MAF is a great idea. I'm not as certain of the benefits of a 90mm over a 75mm in this application. If you already have a good 75mm TB, I would use it and argue the benefits of a larger one at a later date.
I saw 3 lbs of difference between the Blowzilla and Flowzilla inlets with no other changes, using a 75mm TB and LMAF.
Maybe some of that will help.
Thanks Jeff. Just wasn't meant to be for me today I guess. It's a popular size injector, I'm sure another will pop up soon.Sucks that you lost both set of injectors man !
Can't wait to see this thing all done
Without a doubt . If I see anything local I'll keep you in mindThanks Jeff. Just wasn't meant to be for me today I guess. It's a popular size injector, I'm sure another will pop up soon.
