I recently moved to central Texas...and so far my mustang has been pretty pissed off with the hot weather. The engine has been overheating on a regular basis. During the day (with the A/C running - absolutely necessary) my car will run at around 220-235 in traffic (between the "O" up to the "R" of NORMAL on the temp guage). Sometimes, it will even creep up to past the "O". At night or on the highway, it runs at about 200.
What should I do????
So far, I've replaced:
New 1.5" 3 core radiator
High Flow water pump
High Flow 180 Thermostat
New Temperature Sensor
15% coolant / 85% water w/"Water Wetter"
New Ford Racing Oil Cooler
Heavy Duty Fan Clutch
I've also used a block tester kit to check for head/head gasket leaks and I've checked the compression. Both seem fine.
Which option do you recommend:
1.) Buy a new Fluidyne aluminum radiator ($400)
2.) Electric fan + 3G Alternator ($200)
3.) Both 1 and 2 ($650)
4.) Don't worry about it...220-235 is not that hot.
I would really appreciate any input.
Evil Joe
1989 5.0 AOD
145000 miles
mods: 3.55 rear end & no cats.
Funny overheating story: I still use the old freon in A/C system. I haven't changed the accumulator in awhile and I know there is some water in there. One day, my engine heated up to about 260 degrees in heavy traffic. Just as I past a cop directin traffic, one of my A/C lines blew up (probably due to the water pressure) causing a loud bang (like a gunshot). The cop hit the deck, got on the radio, and started looking around. As steam/freon rose from my engine bay, I booked out of there and sped home.
Evil Joe
1989 5.0 AOD
145000 miles
