Yes, remember to plug the 2 exposed ports on back of the engine. I used to large bolts and threaded them in. When i got rid of the A/C i used the ford racing a/c delete braket to move the power steering pump, then got rid of the smog pump, then removed the clutch fan. I did everything in stages so i went through a bunch of belts.....figuring out the size. I also run underdrive pullies. Measure to amek sure you have no contact on your belts and that you running the accessories in the right direction. Sounds simple but the size belts everyone listed didn't work for my setup. If all else fails use a piece of string to measure the belt size you will need. Good luck.
