So i FINALLY got my transmission back up after changin the fliexplate and converter.... put a new filter in... new pan gasket... then while i was tightening the pan bolts down.... i ended up stripping out two of the bolts because i over tightened them....I twisted the torque wrench handle while i was tightening them and torqued them at like 15ft/lbs.... anyways heres the problem... i stripped out the hole where the bolts go in...(the two in the rear corner on the passenger side... The problem now is it only holds 11 out of the 12 quarts before it starts leaking... is it gonna hurt my car if i run with the 11 quarts??? Also how could i fix that??... i was thinking i might be able to take a little bit thicker of a bolt and thread that in and make new threads.... but im sure thats a terrible idea.... i just need some opinions on what to do
