Oh, for times I'm wanting to run 6s on drag radials in the 1/8 mile, and 10s in the 1/4. This certainly won't be right off as my drivetrain needs upgrading and I need to weld in a 10-12 point rollbar w/ swing-outs.
mooktank said:i just bought a T70 with .68 turbine housing for 450 shipped.
shttygtstang said:i just read the new mm ff did any one see the tt cobra inthere compared to the sc's
mooktank said:Actually i got it on ebay. Got it barely used. I didn't even expect to win it.
txplayboy001 said:I have a friend that has been building custom turbo systems for mustangs, vetts, the hemi, etc. (old and newer models) for several years now. There are many possiblities and options when adding a custom turbo to your car. With a STOCK(with high milage) 5.0, one can make the maximum power the block is capable of with no other mods or building. Also, if you get a list of all the parts that you need for a single turbo setup(which is plenty), you can shop around(especially ebay) and put together a complete turbo setup for your fox body for just under 3 grand! I know I have done all of this.
Also if you live in the Houston area I know the guru to go to! He is a perfectionist at his work. I have learned much from him.
sirsureshot39 said:Would u care to share more information and pics of your setup?
bluevenom867 said:What size turbo would you guys use on a large displacment (+400ci) small block to run low 9's?
sirsureshot39 said:What cam would you guys recommend for a (+400ci) small block to run low 9's?
Its not that easy..compressor maps, AR sizing/spool time, drag application, streetability...check out www.turbomustangs.com Look at the turbo sizing charts
