- Jul 12, 2007
- 8
- 0
- 0
I have finally built my car to safely handle some engine mods. I plan on adding Trick Flow's top end engine kit.
If you read the article that 5.0 Mustang did on this install the dyno numbers showed a loss in the 2,000-3,600rpm range. Since my car is mainly a street car, I would love to add power across the powerband. I planned on running a 70mm FRPP throttle body, 75mm Pro-M mass air, 24lb injectors, a JLT cold air intake, 155 fuel pump, and a tune by Lidio Iacobelli at Alternative Auto (the best Mustang tuner in Michigan).
What sized parts should I incorporate to add or keep more low end horsepower and torque with this kit? Am I on the right track with the parts I planned on running or would I be much better off with another companies top end combo such as Holley, Edelbrock, or FRPP?
