Will excessive heat kill batt?
stang730
56
Long Island N.Y.
My car has been sitting in the sun for a few days. The last day i started it up was sat, everything fine. i go to start her up and nothing, tried jumping her and she wount get enough juice to start! no lights left on nothing to drain batt. Battery never seemed to be losing juice, voltmeter always ok. Can the sun be the culprit? Its been pretty hot here last couple of days. Im gonna be bringing the car to the shop for my n2o and gauges and stuff, i guess ill just go for the new batt?
  • Sponsors(?)
HISSIN50
SN Certified Technician
28
129
Nope. Look for a draw while the car is off. Anything more than a couple hundred mA is worrysome.
Good luck.
Darkwriter77
Resident Ranting Negative Nancy
Jul 1, 2005
249
215
104
Apache Junction, AZ
Heat WILL kill a battery over time, but not in one single hot day ... more like over a period of months. Being in the hottest friggin' State in the Union (temperature-wise, at least ... I'm sure most States in the Deep South have us whooped when it comes to sticky, nasty humid heat), the average battery out here in Arizona only lasts about three years, tops. If you get six years' life out of a battery here, either you're a snowbird that stores the car or brings it North for part of the year, or you've got a serious freak of a battery on hand. Even Optima batteries die out pretty quick from the heat out here.
As to why, exactly, I'm not 100% sure. Something about speeding up the whole electrolyte process and thereby shortening its service life, I've heard. And, down here, these people that insist on re-installing those goofy OEM foam battery blankets (not the plastic heat shields) that were meant for COLD climates only make things worse by retaining heat and baking the crap out of the battery. My theory is that in extreme temperatures - hot OR cold - batteries take a harder hit because people are always jammin' on their accessories overtime - A/C, heater, wipers, headlights, etc. - and a lot of cars, especially the late-80's models like Foxes, are equipped with puny alternators that don't put out enough juice to cover the electric bill, so to speak, so the battery takes an extra beating. Batteries, by nature, can only bounce back so many times and with so much energy before they just give up the ghost.
Up in NY, battery blankets are a good thing because it gets friggin' COLD, but out here in the desert ... WHY?!? It never drops below 32* out here but maybe once every 5-10 years on a freak chance, and even then it'll only get to, what, 30*?
Every battery I've had die on me has always done so without any warning at all - perfectly happy one day, then leaves you sitting dead in the water the next. If you get one that gives you a little bit of indication it's getting weak, count yourself either very lucky or very observant - sometimes it's just that one time it cranks a little slow that's the final hint it gives before it poops out (happened to me the one time I borrowed my sister's Honda CR-V for a parts store run).
Thread starter Similar threads Forum Replies Date
cdurbin Excessive Heat 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
M Misfire-Excessive Heat- Melting plastic smell- RPMs stay high after letting off pedal SN95 4.6L Mustang Tech 20
rayvinton excessive heat on rear brakes SN95 4.6L Mustang Tech 3
9646gt Is this excessive heat normal?!? SN95 4.6L Mustang Tech 17
ultimate007 Excessive heat from engine bay SN95 4.6L Mustang Tech 6
ACSPONY Suspension Excess play in rear suspension, springs not staying in place Fox 5.0 Mustang Tech 6
D Excessive shaking during rev up 1965 - 1973 Classic Mustangs -General/Talk- 2
D Excessive sludge found 1965 - 1973 Classic Mustangs -General/Talk- 10
JCBeaver Drivetrain Excessive Vibration at 4K+ RPM while in gears - Any ideas why? 1993 Mustang GT 5.0 with T5 Fox 5.0 Mustang Tech 11
C 98 GT - excessive vapor coming out of one tailpipe in cold temp SN95 4.6L Mustang Tech 1
9 1994 Cobra 331 Dart Supercharged Excessive crankcase Pressure!! Help! 1994 - 1995 Specific Tech 6
W Engine Inconsistent idle and excessive vibration. Fox 5.0 Mustang Tech 17
F Excessive Play In My Steering Wheel Fox 5.0 Mustang Tech 4
rattlecan96gt Modular Headshop/excessive Motorsports 1996 - 2004 SN95 Mustang -General/Talk- 51
7991LXnSHO Allied Nationwide Insurance 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
S Fuel Excessive Fuel Pressure 98 Mustang Gt SN95 4.6L Mustang Tech 10
tbear853 How I Removed Excessive Rear Fender Gap .... Pics 2005 - 2009 Specific Tech 1
98blackstallion 320 Lph In Tank Fuel Pump And Stock Regulator? Excessive Flooding? 1996 - 2004 SN95 Mustang -General/Talk- 4
87_LX_5.0 Excessive Toe-in After Brake/suspension Install Fox 5.0 Mustang Tech 12
R Forged? 6spd? Preemptive or excessive? 2005 - 2014 S-197 Mustang -General/Talk- 11
92BlackWidowHO Hesitation/excessive Backfiring At High Rpms. Fox 5.0 Mustang Tech 16
Pvt_D Excessive smoke any help? Classic Mustang Specific Tech 1
DeadEnd Excessive Cranking?? 1994 - 1995 Specific Tech 10
9 Ring & pinion excessive backlash Fox 5.0 Mustang Tech 5
MRaburn Excess Ford Mustang stock flattens Ford?s Flat Rock facilities StangNet Site News 0
bgdowski Excessive rich condition Fox 5.0 Mustang Tech 5
R excessive drivshaft play? Fox 5.0 Mustang Tech 3
R excessive play 2.3L (N/A & Turbo) Tech 3
Platonic Solid Tire Age: Safety Hazard - Excessive Paranoia - or Sales Promo Classic Mustang Specific Tech 29
B Excessive Fuel Pressure Fox 5.0 Mustang Tech 3
SHOJOE Excessive coolant pressure? Fox 5.0 Mustang Tech 12
grey racer excessive rear brake pad wear 2005 - 2009 Specific Tech 12
98E9GT Excessive Ripple??? SN95 4.6L Mustang Tech 8
9 Piston ring end gap excessive on rebuild Fox 5.0 Mustang Tech 6
DarkoStoj excessive distributor shaft play, msd distributor Fox 5.0 Mustang Tech 2
myponyrocks Excessive shifter movement? SN95 4.6L Mustang Tech 13
hotcobra03 excessive wheel spin =clogged cac SVT Tech Forum 5
XavB excessive bumpsteer with 96 and up spindles Fox 5.0 Mustang Tech 9
deftsound Excessive accessory noise 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 5
Tom95gt excessive wheelhop 1994 - 1995 Specific Tech 8
T 331 Stroker Excessive Crankcase pressure problem 1994 - 1995 Specific Tech 12
T Excessive Crankcase pressure 1994 - 1995 Specific Tech 0
L excessive TV pressure Fox 5.0 Mustang Tech 1
nonglossjason brake floating too excessive Fox 5.0 Mustang Tech 8
R Excessive Play in Steering column after road race practice SN95 4.6L Mustang Tech 4
K overheating and excessive water leaking from exhaust Fox 5.0 Mustang Tech 5
Rickyll7 excessive gear whine GONE after 31 spline swap! SN95 4.6L Mustang Tech 4
grantur01 please help with excessive oil blowing out of motor. Classic Mustang Specific Tech 24
BlackVert loose header bolt = excessive valve noise? 1994 - 1995 Specific Tech 5
1 Engine Light: EGR Excessive Flow SN95 4.6L Mustang Tech 2
