- Jan 11, 2007
- 69
- 0
- 7
any body have tips & tricks for cheap horsepower and you can do it you it by your self.
i will start by reduce 1 quart from engine oil
thats odd...i usually run at least 1/2 a quart extra...as do all of my buddies...any body have tips & tricks for cheap horsepower and you can do it you it by your self.
i see the concept your going behind here, but im assuming that if your looking for cheap do it yourself horsepower that your not driving a highly modded car in the first place. your gonna see very minimal gains from this and its just a risk im not willing to take.reduce oil will reduce windge so horsepower genarate
i know all what you guys said we need new tricks
In the time it takes from exiting the air inlet tube to passing the TB section and entering into the intake itself there is no sufficient time to truely cool or heat the air just too much velocity.
Now lets think about a liquid or compressed o2 injection system...that would cool the air...hhhmmmm...much like the copressed air used to clean computer key boards....now were talking cooling effect. Possibly use a purge like system ......hit da button at WOT....ah likely wouldn't work
well here's something i HEARD works. by-pass the coolant line going into the throttlebody.... they say it cools your throttlebody, and cooler air means more HP. like i said, i dont know, its just something i heard. try it at your own risk. let me know if it works though
Remove the air filter. I wouldn't try it myself though
but the best thing is ditch the fuel injection and go carb you can do it for about 600 or less put some timing in it and pick up 50+ hp.
how do i go about asking for someone to pull codes? who can do this? how much?
