4-wheel disc & rim size
Red
4,517
44
Rahway, NJ
currently i'm running 4 wheel drums on my '68, but this spring i'll be going with 4 wheel disc. i don't know which 4 wheel disc setup i'm using yet. but i have a chance to get a set of AR Torque Thrust Ds ordered cheap through a friend. what size is safe to use to accommodate discs & calipers? i like the look of 15x7s.
any thoughts?
It helps to know which 4 wheeld disc set-up....
I put '07-'09 GT disc un the front and 2000 Crown-Vic on the rear...my wheels are 17x8/225/50 fronts and 17x8/245/50 rear combo...:nice:
no GM crap on my car... :D
I made my disc brake selection based off the fact that I was going to use 15 inch Magnum 500s. I had to make sure not to go too big on the brakes. I went with Granada brakes. Another good option is the factory disc brakes.
any thoughts?
wilwood 12.19" will fit inside a 15" wheel
Posted via Mobile Device
I was thinking about doing the same as you, do you have any pics of the front with the wheel on? also, do you know if '10 is the same?
