You have hit all the suspect problems and replaced the high failure rate parts, so this isn't going to be easy.
Step 1.) Dump the codes. Find some, then post them here and we'll take a look to see if any of them are relevant to your current problem. Fuel pump wiring, sensors and several other systems will post codes to help pinpoint them as possible failure areas.
Step 2.) Don't find any codes, the problem is probably electrical with some loose connections: some critical part like the computer, fuel pump or TFI is losing power or signal and shutting down.
Do things like the radio, A/C or wipers, turn signals get crazy when the engine starts acting up? if so, look at the connector & wiring on the ignition switch very carefully. Tug lightly on the wires to make sure that none of them slide out of the connector shell and none of the wiring shows signs of overheating or other damage.
Step 3.) Check the wiring on the TFI modle: tug lightly on the wires to make sure that none of them slide out of the connector shell and none of the wiring shows signs of overheating or other damage.
Dumping The computer diagnostic codes on 86-95 Mustangs
Revised 19-May-2009 to update drawing for dumping the codes on 86-88 Mustangs with no check engine light.
Dump the codes and see what the computer says is wrong…
Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See
Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Codes have different answers if the engine is running from the answers that it has when the engine isn't running. It helps a lot to know if you had the engine running when you ran the test.
Alternate methods:
For those who are intimidated by all the wires & connections, see
Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see
Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
