What did you do for your Fox today?
I took some pics.
added some fuel and cycled the system to clear out the nasties from sitting for two years, finished up the vacuum lines, and added some break-in oil. First startup should be soon!
past few days i had my radiator out having my friends dad rod it out. he heated up the cap on the driver side of it rad, pulled that off, rodded it out with a dipstick (was super clogged up with corrosion, make sure you use distilled water guys) then we put it back together. painted random motor pieces while we were wating, then put fresh water and super flush in it. gonna wait a few days then drain all of that out and put antifreese, distilled water and rust protector in there.
this morning i pulled my dash pod back off and fixed those tabs again that keep breaking on my car, then i got the headlights aimed up. one of the adjustment screws was bent so it was camming its way around and being difficult to aim.
I changed the exauhst crossover valve, if your going to do it get a 1 1/16 for the back side bolt on the crossover tube and a 1 1/4 for the bolt on the valve. took mine out and the guts fell out, that and the many cracks and rotted holes in it tells me that it was probably bad.
got bored last night so I pulled the windshield trim and rattlecan'd it with Duplicolor flat trim. Not show car finish but better than the flaking mess they were.
