darkhorse1 Founding Member Jun 21, 2002 121 0 16 Indiana Mar 21, 2008 #1 Mar 21, 2008 #1 What exactly will I need for a 5 lug conversion on my 92? I'm on a budget,so used parts are a plus. Thanks.
ttop88 Member Mar 12, 2007 42 0 6 indiana Mar 21, 2008 #2 Mar 21, 2008 #2 Depends on what wheels you want to run. Ranger axles and drums in the rear and lsc rotors in the front is the cheapest I have found but it limits wheel choices.
BK_CAULEY it's built for speed not longevity, woman Dec 26, 2006 0 10 49 Thomasville, ga Mar 21, 2008 #3 Mar 21, 2008 #3 i did my first 5 lug swap with sn95 spindles ranger axles and it cost me $175 from the local pick and pull. on a side note i have some lincoln spindles, rotors and calipers i will let go REAL cheap.
darkhorse1 Founding Member Jun 21, 2002 121 0 16 Indiana Mar 21, 2008 #4 Mar 21, 2008 #4 I'm wanting to run the dark gray bullit wheels on the street, and then a set of slicks on the track.
ttop88 Member Mar 12, 2007 42 0 6 indiana Mar 21, 2008 #5 Mar 21, 2008 #5 Then you haft to use 94-95 hub and spindle on the front.
Redfire 05 New Member Apr 6, 2005 236 0 0 Lubbock, TX Mar 21, 2008 #6 Mar 21, 2008 #6 Go to this site and click on 79-93 5 Lug Ford Fox Body Conversions ... Pretty detailed explanation of different ways to add 5 lugs http://svo73mm.cjb.net/
