Hey all.. new here. Go easy on me.
Spent some time reading and while every issue can be its own unique cup of tea, figured I would ask the pros for some advice.
Some info I post here might be irrelevant but I don't know a lot about cars so posting as much as I can if it helps.
I have a 90 5.0 that I just finished doing a cam, head, intake swap on. The main rebuild like cam install, setting rockers and lower intake I had the help of a family heavy duty mechanic so my noobness had some help. Also had his help setting timing. Doesn't mean it's perfect but at least I wasn't solo being new to this.
So
- new comp cam (don't know specs sigh) was from a buddy's new build he ran for a week then wanted more power so did a full engine swap.
- new AFR 58cc heads (his heads)
- new push rods (his rods)
- new lifters (his lifters)
- new comp rockers - 1.6 ratio
- edelbrock Performer RPM 2 intake
- BBK 70mm throttle body
- BBK cold air intake
- new MSD distributor cap only and new plug wires
- new spark plugs
- deleted ERG and probably all emission stuff
- stock fuel injectors
- stock rails
- stock mass air sensor
- stock water, alt, power steering pump
- stock headers
- stock exhaust
- deleted smog pump
Fired the beast up and it sounds mean, it idles perfectly, to me anyways.. revs up good.
Hear a bit of a whine or squeal which I think might be a vaccume leak somewhere.
Problem:
no power.. driving it down the road it just doesn't want to go. Best way to describe it would be driving in to high of a gear for the RPMs you are at then pushing the gas. But it doesn't sound like it drowns out when you push the gas just drives. Think a mono toned person talking. That's this beast even in second gear.
Not sure where to start... new mass air sensor? Get a code reader and see what's going on with the newly deleted stuff? New injectors needed with all this new air flow ?
Just take it to the local dyno shop for a tune ?
Any advice would be awesome.
So
- new spark plugs
- stock rails
- stock headers
- stock exhaust
- deleted smog pump
Problem:
