Hello ladies, gentlemen and n00bs, here is an all new thread for your viewing pleasure. Herein I'll be compiling links to threads that answer some really common questions, and in the process hopefully spark some intelligent conversation and build upon Fox Talk/Tech's knowledge base. This will be an ongoing effort, so please feel free to post suggestions for common questions or additional threads with which to answer already listed questions. For starters, this sticky gets overlooked VERY frequently, and it already answer a lot of tech questions that get asked on a daily basis: Fox Tech's Technical and How-To Thread Check that out first if you're new to the site or new to the Fox Mustang game in general. If you're looking for something else, below is the list that we have so far. Please feel free to reply to this thread and/or PM me with any suggestions for additions. Like I said above, this will be an ongoing effort, so realize it may not be very heavy right off the bat. Engine Performance What size throttle body should I use? http://www.stangnet.com/mustang-forums/818051-90mm-throttle-body-overkill.html http://www.stangnet.com/mustang-forums/764787-throttle-body.html http://www.stangnet.com/mustang-forums/747160-quick-q-throttle-body.html What size/type MAF sensor should I use? http://www.stangnet.com/mustang-forums/614633-will-maf-sensor-work.html http://www.stangnet.com/mustang-forums/564052-help-mass-air-meter.html http://www.stangnet.com/mustang-forums/601156-73-76mm-mass-air-meter.html How much power can the stock block take? http://www.stangnet.com/mustang-forums/679536-500rwhp-real-limit.html http://www.stangnet.com/mustang-forums/735096-2-bolt-strengthening.html What is the difference in GT40 (tubular)/Cobra/Explorer intakes? http://www.stangnet.com/mustang-for...orer-gt-40-intake-thread-56k-dont-bother.html What is the difference in GT40 heads?/What do I need to use GT40-Ps? http://www.stangnet.com/mustang-forums/581864-quick-gt40p-question.html What belt size do I need to omit X accessory? http://www.stangnet.com/mustang-forums/646822-schematic-routing-short-belts.html http://www.stangnet.com/mustang-forums/780587-how-delete-smog-pump-reroute-belt-302-5-0-mustang.html http://www.stangnet.com/mustang-forums/728664-what-size-short-belt-combo.html What are the best "beginning" mods? http://www.stangnet.com/mustang-forums/813753-noob-5-0-mustangs-buying-one-best-mods-what-look.html http://www.stangnet.com/mustang-forums/806087-best-foxbody-mods.html What is better, H-pipe or X-pipe? http://www.stangnet.com/mustang-forums/803353-x-pipe-sound.html http://www.stangnet.com/mustang-forums/789453-catted-h-x-pipe-offers-best-ground-clearance.html http://www.stangnet.com/mustang-forums/713247-difference-between-h-x-pipe.html http://www.stangnet.com/mustang-forums/819607-h-pipe-have-deeper-sound.html What muffler/cat-back sounds/performs the best? http://www.stangnet.com/mustang-forums/732868-bassani-magnaflow.html http://www.stangnet.com/mustang-forums/734790-loudmouth-1-vs-2-a.html http://www.stangnet.com/mustang-forums/727642-hmmm-what-mufflers-get.html http://www.stangnet.com/mustang-forums/726096-pypes-exhaust.html http://www.stangnet.com/mustang-forums/760790-flowmaster-vs-dynomax.html http://www.stangnet.com/mustang-forums/766444-exhaust-clip-mega-thread.html http://www.stangnet.com/mustang-forums/778632-idle-rev-clips-post-em-up.html EFI Mysteries and Electronics How do I set my TPS voltage? Does it really need to be right at 0.99999999V? http://www.stangnet.com/mustang-forums/825424-adjusting-your-tps-0-98v-not-necessary.html What injector size do I need?/Will these injectors work with my MAF? http://www.stangnet.com/mustang-forums/848192-what-injectors-do-i-need-my-build.html What do I need and how do I install a 130A alternator? http://www.stangnet.com/mustang-forums/646825-3g-alternator-install-how.html How do I wire in an electric fan? http://www.stangnet.com/mustang-forums/threads/wiring-issue.833403/ http://www.stangnet.com/mustang-for...-gurus-wiring-a-fan-off-warning-light.667390/ Handling and Suspension I want to lower my car, what springs/shocks/struts should I use? http://www.stangnet.com/mustang-forums/678593-lowering-springs.html http://www.stangnet.com/mustang-forums/500680-frpp-lowering-springs-any-opinions.html http://www.stangnet.com/mustang-forums/826771-should-i-lower-my-car-thinking-about-b-springs.html Will I have wheel hop if I remove the quad shocks? http://www.stangnet.com/mustang-forums/778532-quad-shock-debate.html What upper/lower control arms should I use? http://www.stangnet.com/mustang-forums/803791-whats-best-choice-upper-lower-control-arms.html http://www.stangnet.com/mustang-forums/812566-so-why-those-summit-control-arms-were-so-cheap.html What about general suspension/chassis information? http://www.stangnet.com/mustang-forums/758792-best-k-member-stock-arm-springs.html http://www.stangnet.com/mustang-forums/805996-aftermarket-k-member.html http://www.stangnet.com/mustang-forums/789304-can-i-make-5-0-handle.html Wheels and Tires How do I convert to 5 lug? http://www.stangnet.com/mustang-for...ug-5-lug-brake-conversion-upgrade-thread.html How big of a wheel/tire can I use? http://www.stangnet.com/mustang-forums/716968-wheel-backspacing-offset.html Appearance/ Body Where are all the nice Foxes? http://www.stangnet.com/mustang-forums/539102-thread-nicest-foxes.html http://www.stangnet.com/mustang-forums/759233-fotm-voting-rules-regulations-fotm-archives.html Should I convert my 4-eye to an Aero nose car? http://www.stangnet.com/mustang-forums/771054-before-you-butcher-4-eye-56k-beware.html Drivetrain What is my gear ratio?/What gear ratio should I use? http://www.stangnet.com/mustang-forums/544202-what-gear-ratio-do-i-have.html http://www.stangnet.com/mustang-forums/598843-3-08s-3-73s-how-big-difference.html http://www.stangnet.com/mustang-forums/403409-guys-who-went-2-73s-4-10s-lets-hear-your-opinions.html http://www.stangnet.com/mustang-forums/549477-aods-3-73-gears.html http://www.stangnet.com/mustang-forums/813795-rear-end-gears-3-55s-3-73s.html What speedo gear do I need? http://www.stangnet.com/mustang-forums/830254-3-73-rear-end-speedo-gear.html How strong is the T5? http://www.stangnet.com/mustang-forums/815587-school-me-5-spds.html What is the best short throw shifter? http://www.stangnet.com/mustang-forums/829314-tri-ax-vs-pro-5-0-vs-mgw-t5.html How strong is the 8.8 rear end? http://www.stangnet.com/mustang-forums/731024-when-stronger-axles-needed.html How do I swap from an auto to a manual transmission? http://www.stangnet.com/mustang-forums/811276-t5-swap-questions.html General Maintenance and Repair How do I replace my heater core? http://www.stangnet.com/mustang-forums/646250-replacing-heater-core.html http://www.stangnet.com/mustang-forums/680267-heater-core-comparison-question.html Random and Etc. Is my car a Cobra? http://www.stangnet.com/mustang-forums/838277-my-car-cobra-definitive-answer.html http://www.stangnet.com/mustang-forums/838138-do-i-have-real-cobra.html Where can I find production numbers for my car? http://www.stangnet.com/mustang-forums/530421-official-fox-body-production-number-thread.html Is there a place where I can find information on other member's cars, how they built them, and how they perform? http://www.stangnet.com/mustang-forums/761371-official-progress-threads-thread.html http://www.stangnet.com/mustang-forums/677534-dyno-1-4-mile-time-thread.html Do we have any old archives of general Fox Mustang information? http://www.stangnet.com/mustang-for...old-5-0-mag-articles-i-need-your-support.html http://www.stangnet.com/mustang-forums/789387-some-old-mustang-test-videos.html http://www.stangnet.com/mustang-forums/725558-fox-mustang-trivia-thread.html Contributors so far: Me! (@NikwoaC) @skunk21 @No.11 @wythors @jrichker @Saleen0679 EDIT: I'll finish this as I get suggestions and as I have time.
Can you supply links to valid threads that cover this info? If you do that, I'll include them in my original post. Thanks!
Fan controller with relay: http://www.stangnet.com/mustang-forums-old/833403-wiring-issue.html#post8395077 Fan controller with switch: Note that I DO NOT recommend this approach. It is too easy to forget and do some damage http://www.stangnet.com/mustang-for...wiring-fan-off-warning-light.html#post6488364
Try http://www.stangnet.com/mustang-forums/threads/wiring-issue.833403/ and http://www.stangnet.com/mustang-for...-gurus-wiring-a-fan-off-warning-light.667390/
