#1.raise car,set on jack stands.
#2.remove cover.
#3.remove ccrm bracket and overflow tank.set aside.
#4.remove fan,set aside.
#5.push down,remove belt.
#6.using 15/16 socket,remove crankshaft bolt.(i did this from under the car,just easier to take pic from top.if you dont have an impact wrench,with an assistant,remove starter,wedge large screwdriver against flywheel to prevent it from turning,while you loosen the crankshaft bolt with a long breaker bar.).
#7.remove 4,1/2 inch crankshaft pulley bolts.(also from under car)
#8.using puller,draw HB off crankshaft.
----old HB going bad----
new HB from autozone.pioneer DA-3021.$98.
#9.clean off crankshaft snout.place rtv sealant on HB keyway.(some chose to install new timing cover oil seal,i put new cover w/seal 2 years ago so i skipped that step)
#10.carefully slide HB on crankshaft,lining up the crankshaft key with HB keyway.
#11.using rubber mallet or a peice of wood,lightly tap HB onto crankshaft.
#12.clean off crankshaft bolt and washer,install on crankshaft finger tight.DO NOT FORCE IT.if to tight remove it,make sure it's clean and try again.
#13.using short bursts from the impact wrench,slowly draw HB onto crankshaft until fully seated.tighten crankshaft bolt to 130 foot pounds.
#14.reinstall crankshaft pulley(i used a very small dab of locktite on the 4 bolts)
-----look at the pullies from the side,make sure they all line up-----
#15.reinstall the belt.make sure everything's straight.
#16.reinstall fan.
#17.reinstall ccrm bracket w/coolant overflow tank.
#18.reinstall cover.look everything over.
#19.start car.bring to normal operating temp.shut off.
#20.remove spout connector.
#21.hook up timing light.inductive pick-up on #1 plug wire.pos and neg to battery.
#22.start car,check timing,adjust as needed.factory base timing is 10 degrees BTDC.shut off car.(i set mine at 13 BTDC)
#23.reinstall spout connector.
#24 start car,check timing to ensure it is advancing beyond base timing.
#25.lower car.your done!grab a drink,and relax.
#2.remove cover.
#16.reinstall fan.
