Here in AZ it has been in the 100's and I have to run the A/C, but when I do it feels like it is putting so much stress on the crank!
When I use the a/c the oil pressure is a little lower, the car runs hotter, and when I take off from a stop and don't have the RPM's high enough I get a BAD rod knock. You know the kind when the engine bogs on itself when you let the clutch out... It makes my skin crawl when I hear that.
While I'm driving at any speed around 2000 rpm, my oil pressure is at 40-50 psi. At idle after warming up to full operating temp it's at 20-25 but when the a/c is on it's more like 20 and a little under. What if it starts to dip below 20 after a while? Am I just driving myself crazy by worrying too much?
I also have a T-trim to install but now I'm rethinking it. It would just be more stress on the crank.
BTW the block has approximately 50-75,000 miles on it. I'm not sure since I bought the car used and discovered cross hatching in the cylinders when I did the HCI.
Thanks for any input.
