Please HELP i'm at wits end. I have a boss block 363 with custom grind cam, afr 205 heads, 78 lb fuel injectors, pro m 98 mass air meter, trick flow type R intake, A-1000 fuel pump, 1.75 hooker headers, and i'm using the pro m efi computer that replaces the entire factory computer, vortech v-7 ysi with pulley that came with kit. Once I start the car it take about 2 mins for the headers to start glowing at a idle. I have retarded timing advanced timing and end up with same results. I made a injector cleaner and used carb cleaner to run through injectors, not sure if that could hurt them? I'll take any advice and thank you all i advance.
