Ok I bought this 93 5.0 about a month ago. The car was running pretty good and fast, but I noticed he had a mass air meter calibrated for 24# injects, but only 19# injectors in. So I took off the upper manifold and put in my 24# injectors in that I had sitting in my garage for about 2 years. Anyways I bolted everything back up and even cleaned the egr and IAC with intake cleaner. I started it up it idles about 900 rpms, but at least it is constant.
so I hop in and go take a test drive and hardly any power what so ever, I go to step on it and it is sooo slow, It almost feels like compression lost, but I checked my compression before I put in the 24# injects and everything checked out fine and I know its not the gasket on the upper intake either, I put that on really good.
Could some of my injectors be bad? My fuel pressure guage is at 41 psi (vac off). This sucks, any know if this could be my injectors?
