just rebuilt my engine. now that Im over 500 miles on it I thought I would do a few high rmp runs. when i installed the 185 AFR heads & new roller rockers, the instructions on the rockers said to tighten the nut down until there was no slack then go 1/2 to 1 turn more. i noticed that when doing this. on some of the lifters, the plunger would be depressed by the additional turn but others did not. i soaked the lifters for about a week befor installing them. they are factory original lifters also. once the engine was back in the car and running, it sounded like the rockers were tapping. I pulled the valve covers and found that the rockers had quite a bit of play in them. I loosened the lock bolt and tightened the nut with my fingers until there was no play and gave another 1/2 turn with a wrench. after doing all the rockers like this i rechecked the first one and it was sloppy again. is this normal? at about 6000 the engine seems like it hit the rev limiter but it is set at 6700. could the rockers be to tight?
