thank you sirI had a delightful dill havarti today. That engine looks exquisite as well.
The Yellow is Actual AFR, the blue is target and the green below is RPM
The big lean spikes are decel, there are actually settings to have the injectors cut off entirely (i guess for fuel conservation?) but id prefer to use the fuel for cooling.
See you'd be pumping at that point HOT air, which is all relative I guess so I see your point.Explain how adding fuel to a cylinder on decel causes a "cooling effect". If you add fuel, and the fuel is ignited and burns, the combustion would create heat, not a cooling effect. By cutting off all fuel on decel, you are just pumping air through the cylinder, which in my opinion would create more of a cooling effect than actually having a combustion process. Yes?
Thanks Nick,Looks great! Glad to see it almost ready to rock and roll!
You could lean your idle table out a little more if your at 13-13.5 now. I typically like the idle a/f's in the 14's
Just to play devils advocate here......So the air that is being compressed on the compression stroke with no fuel is going to be hot, but, is it going to be hotter than the piston or combustion chamber that it is being compressed in. Now take that same air and add fuel and ignite it. Which will be hotter? And then the whole "fuel that you aren't igniting, within a reasonable amount". How do you get to that? How do you only burn some of the fuel during combustion, but not all of it, so that the fuel that does not burn somehow causes a "cooling effect"? Again just playing devils advocate.See you'd be pumping at that point HOT air, which is all relative I guess so I see your point.
I guess (I'm not trying to pretend to know more than I do here) the idea is fuel that you aren't igniting, within a reasonable amount, has a cooling effect within the cylinder.
I'm not trying to push anything as fact here, just repeating info I picked up from another holley user
I had just decided not to mess with the feature while I had so much else to learn
Thanks Nick,
I think I'll do just that
See I don't entirely understand the concept myself. I guess my original post makes it sound like it's something I was doing, which at the moment I'm not.Just to play devils advocate here......So the air that is being compressed on the compression stroke with no fuel is going to be hot, but, is it going to be hotter than the piston or combustion chamber that it is being compressed in. Now take that same air and add fuel and ignite it. Which will be hotter? And then the whole "fuel that you aren't igniting, within a reasonable amount". How do you get to that? How do you only burn some of the fuel during combustion, but not all of it, so that the fuel that does not burn somehow causes a "cooling effect"? Again just playing devils advocate.
Whoever (Noobz) changed the title of my thread...
It shall stay
It shall stay
The Only Part Of A Chevy You Don't Have To Tow, Into An Sn95.
Thanks mang. It's quieter with the pipes for sure, and they'll probably come back off for track days but I'm good with it for now. Hopefully we'll get some rolling video next week. Really itching to drive it.Stop it. I can't find the thread when you do that............
I just watched the video on page 13 of thread. Sounds frkn awesome. That is going to be a beast going down the road. I plan on running 40 series FM's on mine. Curious on what it will sound like though.
Exhaust note isn't really a concern on this build. Put enough motor in front of the muffler and it becomes irrelevantchevy and flowmaster dont go together, flowmaster and mustang go very well together, chevy longtube and dump before axe ^^ sound best. or SLP
