at 320 rwhp for any. or whenever you want to easily make this kind of hp.
http://www.corral.net/forums/showthread.php?t=636840
- - - - - - - - - - - - - - ***** THE OFFICIAL HP LIST*****
Z06KILLR (670 SAE) 5.4 DOHC, Ford GT Heads, Crower Stage III Cams, 2000 Cobra R Intake, 14lbs boost, no intercooler.
3blk98Cobra (661 SAE HP), on pump gas, 98 Cobra, 8.7:1 4.6 shortblock, ported stock 98 Cobra heads, twin 57mm HP turbo kit, SCT BA2800 MAF, MSD DIS-4, Accufab single blade TB, 72lb high imp inj, twin 255lph fuel pumps
1BAD98 (646 SAE HP) 98 Cobra, Built motor,
Vortech JT trim with 3.10 ultra grip pulley, Stage 2 blower cams, ported and polished heads, 55lb injectors, TKO tranny, short runner intake (ported), no IMRC plates, weldon fuel pump, long tube headers with 3 inch pipes out the back. 103 octane gas, 13-14 psi.
SNAKBTN (603 SAE HP) 98 Cobra, Totally stock untouched from the oil pan to throttle body
S-trim with 2v impeller upgrade, 3.125 RR pulley 7800 rpms, RG
Blown01NJ (577 SAE HP) 01 GT w/ 2001 Cobra motor,Forged bottom end, P&P Intake, Vortech SQ (GT Impeller), 2.95 pulley, GI Joe 8-rib kit, AFM PP, Vortech mini race bypass, 60lb injectors, MD -8 fuel line upgrade,KB BAP, Wiring upgrade, Full Exhaust, 11.5's across the board 16* total timing.
VIPERBLUELX (560 SAE HP) 96 Cobra 283ci, Ported 01 heads, stock cams, stock intake, intercooled P1SC, 72lb injectors, 17psi boost, pump gas
VenomousSvt (548 SAE HP) 2001 cobra Forged shortblock Manley Pistons Manley Rods Coated bearings 9.0:1 Procharger D1-SC 12.5psi 3 core intercooler stock heads stock intake (for a few more weeks) stock cams
sc96cobra (530 SAE HP) 96 Cobra, forged short block 9.5.1 compression. Stock heads and Cams. Vortech V-1 upgraded impeller. 3.12 pulley with power pipe. BAS 42's injectors, 255 inline, 255 intank, AN-8 feed, AN-6 return.
Evan5469 (520 SAE HP) 98 Cobra, V-1 S-trim w/ aftercooler, Forged bottom end, stock intake, stock heads, stock cams,
BBK long tubes, catted BBK H, MAC catback, 77 Pro-M, about 16 psi, 93 octane
JWBZSVT (514.6 SAE? HP) 01 Cobra, JMS built motor, stock heads & cams, vortech s/c 12 psi, intercooler/aftercooler, JMS built power pipe, Mac Lt's jet hot coated, Mac Cat-back, 42 lb injectors, 03 Cobra fuel system, 4.10's, JMS chip.
Blown97Cobra (508 SAE HP) 97 Cobra 4.6, stock heads, stock cams, stock intake, Vortech V-1 w/ GT impellar upgrade, Snow Performance H2O Injection 55lb injectors, 16psi boost, pump gas
Bincky (500.5 SAE HP) 2004 Mach 1, D1-SC Procharger, 4.15" blower pulley, custom high-flow blower inlet, 11psi peak boost, 39lb. injectors, SVT Focus fuel pump, Bassani off-road x-pipe,
Magnaflow cat-back, stock motor/heads/cams/intake, pump gas
- - - - - - - - - - - - *****THE OFFICIAL TQ LIST*****
3blk98Cobra (663 SAE TQ), pump gas, 98 Cobra, 8.7:1 4.6 shortblock, ported stock 98 Cobra heads, twin 57mm HP turbo kit, SCT BA2800 MAF, MSD DIS-4, Accufab single blade TB, 72lb high imp inj, twin 255lph fuel pumps
Z06KILLR (540 SAE) 5.4 DOHC, Ford GT Heads, Crower Stage III Cams, 2000 Cobra R Intake, 14lbs boost, no intercooler.
VIPERBLUELX (540 SAE) 4.6, Ported 01 heads, stock cams, stock intake, intercooled P1SC, 72lb injectors, 17psi boost, pump gas
1BAD98 (534 SAE) 98 Cobra, Built motor, Vortech JT trim with 3.10 ultra grip pulley, Stage 2 blower cams, ported and polished heads, 55lb injectors, TKO tranny, short runner intake (ported), no IMRC plates, weldon fuel pump, long tube headers with 3 inch pipes out the back. 103 octane gas, 13-14 #'s boost
Blown01NJ (506 SAE) 01 GT w/ 2001 Cobra motor,Forged bottom end, P&P Intake, Vortech SQ (GT Impeller), 2.95 pulley, GI Joe 8-rib kit, AFM PP, Vortech mini race bypass, 60lb injectors, MD -8 fuel line upgrade,KB BAP, Wiring upgrade, Full Exhaust, 11.5's across the board 16* total timing.
SNAKBTN (499 SAE) Totally stock untouched from the oil pan to throttle body
VenomousSvt (480 SAE) 2001 cobra Forged shortblock Manley Pistons Manley Rods Coated bearings 9.0:1 Procharger D1-SC 12.5psi 3 core intercooler stock heads stock intake (for a few more weeks) stock cams
Blown97Cobra (463 SAE) 4.6, stock heads, stock cams, stock intake, Vortech V-1 w/ GT impellar upgrade, Snow Performance H2O Injection 55lb injectors, 16psi boost, pump gas
sc96cobra (450 SAE) 96 Cobra, forged short block 9.5.1 compression. Stock heads and Cams. Vortech V-1 upgraded impeller. 3.12 pulley with power pipe. BAS 42's injectors, 255 inline, 255 intank, AN-8 feed, AN-6 return.
JWBZSVT (449.4 SAE?) 01 Cobra, JMS built motor, stock heads & cams, vortech s/c 12 psi, intercooler/aftercooler, JMS built power pipe, Mac Lt's jet hot coated, Mac Cat-back, 42 lb injectors, 03 Cobra fuel system, 4.10's, JMS chip.
Evan5469 (430 SAE) 98 Cobra, V-1 S-trim w/ aftercooler, Forged bottom end, stock intake, stock heads, stock cams, BBK long tubes, catted BBK H, MAC catback, 77 Pro-M, about 16 psi, 93 octane
Bincky (424.1 SAE TQ) 2004 Mach 1, D1-SC Procharger, 4.15" blower pulley, custom high-flow blower inlet, 11psi peak boost, 39lb. injectors, SVT Focus fuel pump, Bassani off-road x-pipe, Magnaflow cat-back, stock motor/heads/cams/intake, pump gas
__________________
www.chattanoogastangs.com
99 Rio Red Cobra coupe w/ 04 Mach 1 longblock, LDC cooling mod, D1SC @ 8psi, ported(by me) lower intake, UPR X-pipe, FR500 catback, 03 IRS w/3.55 gear and billetflow brace, 39lb injectors, 03 Cobra fuel pumps, Diablo MAFia, custom Xcal2 tune by Lasota Racing, Steeda Tri-Ax, Spec stage I.
414rwhp/391rwtq
http://www.corral.net/forums/showthread.php?t=515518
Scott@VT Engines (600+/430 SAE) 3.7" Bore, Proprietary Stroke, Ported 05+ GT's (4valve) by Al/Cams/Sullivan Intake/Carbureted/RG. N/A HP Champion.
Boss 330 (593 SAE) 5.4L, Ported 05+ GT's (4valve) by Al/Cams/Carbureted/RG/Dry Sump.
Randy Haywood (548/439 STD*) 5.4L, Ported '00R's/Cams/Sheetmetal Intake/Carb.
Mike T. @ Modular Performance (507 SAE) 5.0L, Ported FR500/PSR/Cams/RG.
Joe Hutchins (475) 5.3L(SHM), Ported B head/Cams/Kinsler IR intake/RG.
James Lasurdo (svtsnake.com) (470/380 SAE) VT 5.3L, Ported FR500 Heads/FR500 Intake/Cams.
Nazman (459/376) 5.0L Big Bore, Owner Ported FR500's/FR500 Intake & Cams.
Shawn Johnson (454 STD*) 5.0L, Ported C Heads/Mod Perf Cams/Custom Intake/Carbureted/RG.
WMS (448 SAE) 5.3L, Ported C Head/FR500 Intake/Cams.
Paul S/PHP (430) 5.0L, Ported FR500/FR500 Intake/Cams/RG.
360NotchforUrLS1 (420/390) Ported 99/01 C head/Ported Intake/Crane Cams.
Dennis Sharp/DS97Cobra (420/330 STD*) 5.0L Ported FR500/FR500, Houston Perf Cams.
Shalom96 (410/337 SAE) 5.0L Stroker, Ported C(03) Heads/Short Runner Intake/Houston Perf Cams.
Nazman (from Mighty Mustangs) (410/333 SAE) Owner Ported FR500 Heads/FR500 Cams/FR500 Intake. 4.6L HP Champion.
01CobraSVT TICO (410/323.5 SAE) 5.0L BB/Ported 01 Heads/Hensler Spec Cams.
Mystic1/Ted S. (414/335 STD*) 5.0L, Ported 01 Heads/FR500 Intake/Mod Perf Regrinds.
Blacksnake305 (lafear01) (388/376 SAE) 5.0L BB, Fox Lake Ported 01 Heads/Joeys PI/FR500 Cam.
Ron 99 Cobra (385) 5.0L, Ported C Head/PSR.
Shawn Johnson (374 SAE) 99' .020 over cylinder bore, valve job, stock cams & intake set up for Factory Stock race class..
C Weil (372/324 SAE) 5.0L, Ported B Heads/SSR intake/FR500 Cams.
Jims SVT (370/318 SAE). JSR (jims svt) Ported Short Runner. Ported96-98 B head/Cams.
Joe Lynch (370/300 SAE) Ported C Heads/PSR Intake/Houston Perf Regrind Cams.
James Hensler (370 SAE) Ported B Head/HCI intake/Cams/RG.
ITLRUN (363.8/311.3 SAE) Bowl&Valve Work by Al on 03 heads/FR500 Intake/Stock Mach Cams.
David Simmons (car now owned by C Weil) (360/326 SAE) 5.0L, Ported B Heads/SSR intake/FR500 Cams.
vrtical (360/320 SAE) Ported 01 C Head/Aviator Intake/Crower Cams/RG.
Bob Cosby (356.2@6100/337.4@5000 SAE) 99' .020 over cylinder bore, valve job, stock cams & intake set up for Factory Stock race class.
ddmander (356/355 SAE) 5.0L/Ported C Heads/Extrude Hone Intake.
Silver01Cobra (356/348 SAE) Ported FR500 Heads/Ported Intake/FR500 Cams.
jcitroloc (353/355 SAE) 5.0L BB/Ported Intake/03 Mach C head with prep work by Boss 330.
Barry Shepard (350) Ported FR500 Heads/FR500 Intake/Cams/RG.
99BlackVenom (350/329 SAE) Ported FR500's/Extrude Hone Intake/SHM Stage2 Cams.
Duane V (346/293 SAE) Ported B Head/PI/Crower Regrind Cams/RG.
RedCobraVert (346/318 SAE) Ported C Head/Cams.
Nazman (from Mighty Mustangs) (337/337 SAE) PI, 99 C head. Bolt on HP Champion.
huzsvt (337/336 SAE) SHM stage 2 ported intake and stage 1 ported 99 C heads/Crower Cams.
4VMENACE (335/319 SAE) PSR/Ported 97 B head/SHM Cams.
ExplorerThis (from SVTPerformnce) (331.65/323 SAE) 01 C head.
tmhutch (331.6/325 SAE) PSR. 01 C head.
CYA (from SVTPerformnce) (330/320 SAE) Ported, extrude honed intake. 01 C head.
Jeff Peterson (330 SAE) PI. 01 C head.
Stedda (328/321 SAE). 01 C head.
Quick01snake (327/327 SAE). 01 C head.
Jims SVT (326/305 SAE). JSR (jims svt) Ported Short Runner. 96-98 B head.
stockmach1 (mch 1 regstry.com) (324/337 SAE) 03 C head.
4V GTS (322.4/317.9 SAE). C head.
32VHEMIJR (322 SAE) PSR. C head.
BEERFORMEPLZ (321/353! SAE) 04 Mach.
MODSTER (320). C head.
Skyler (320/319 SAE) PI by Naz. C head.
TxSnakeCharmer (320/310 SAE) Extrude Hone Intake. C head.
103 (Dustin) (320/315 STD*). C head.
RUNNINFAST (320/299) B head/ported intake/dome pistons/SHM cams.
Joe98Stang (319/309) C head.
COBRACIDE (319/316) C head.
99SVTAddict (318/315 SAE) PI. C head.
SVT CAMR (318/290 SAE) Ported Intake. 96-98 B head.
Red01 (316/321 SAE) 01 C head.
torque list
Boss 330 (520/440 STD*) 5.4L, Ported Navi/Cams/PSR/RG.
Randy Haywood[/b][/color] (548/439 STD*) 5.4L, Ported '00R's/Cams/Sheetmetal Intake/Carb/RG.
Scott@VT Engines (600+/430 SAE) 3.7" Bore, Proprietary Stroke, Ported 05+ GT's (4valve) by Al/Cams/Carbureted/RG.
Blacksnake305 (lafear01) (388/376 SAE) 5.0L, Ported Heads/Joeys PI/FR500 Cam.
ddmander (356/355) 5.0L/Ported C Heads/Extrude Hone Intake.
BEERFORMEPLZ (321/353! SAE) 04 Mach with bolt ons.
Nazman (from Mighty Mustangs) (376/341 SAE) Owner Ported Intake/Owner Ported FR500 Heads/FR500 Cams.
Bob Cosby (356.2@6100/337.4@5000 SAE) Untouched heads/cams/intake.
Nazman (from Mighty Mustangs) (337/337 SAE) PI.
Mystic1/Ted S. (414/335 STD*) 5.0L, Ported C Heads/FR500 Intake/Mod Perf Regrinds.
99BlackVenom (350/329 SAE) Ported FR500 Head/Extrude
Blown46Cobra/David Simmons (360/326 SAE) 5.0L, Ported B Head/SSR intake/FR500 Cams.
tmhutch (331/325 SAE) PSR.
RedCobraVert (346/318) Ported C Head/Cams.
COBRACIDE from Corral (318/317).
TxSnakeCharmer (316/308 SAE) Extrude Hone Intake.
Hone Intake/SHM Stage II Cams.
note: notice where my torque falls on this list.
