I didn't have to but I did not want to cut and modify my AC lines until I knew that the KB install was going to be successful and run well. Most likely I'll reinstall it this winter but I may not do it at all because honestly I don't ever use it. I have kept most everything for the car to make it stock again just in case I feel the need to someday.You had to give up ac?
Thanks bro! The car feels good in boost but it's rich and I'm sure would pull harder once it gets leaned out to just the right amount. We are taking a little out each time but I'm too much of a poosy to go WOT and achieve full boost to get a well informed data log. I wanted to yesterday on the way home but it started raining on my commute homeCongrats! Car looks great and I'm sure runs like a beast!
Sweet thanks! Waiting on a call back from themCheck out Devilsown injection systems. Only 300 for stage 1
395 for the stage 2 progressive kit.
I am injecting mine based on tps and rpm.
When I'm in wot (90% tps or greater) and above 3500rpm I want the meth to kick on. The only purpose is to lower intake temps.
Isn't meth bad for your teeth!^^This sounds like a perfect way to activate meth with a PD supercharger. You the man Steve! Thanks
Thanks bro, I have the Lisle tool waiting around for the inevitable to happenWith that 5.4 motor it really helps to run an intake cleaner through it before pulling the plugs. It helps to break up any carbon on the tips. Turn just a little at a time, back and forth, and they'll come out ( usually ) without a problem. Those things are a PITA.
That car is amazing man. You guys are really keeping me motivated with all these pictures.
I'll get some data from it. It's going to be a tuning session as well so I can get WOT and timing dialed in the best. I rarely get to drive in my car alone and when I do there is not enough road to get to WOT and just let it eat. These 3.73 gears aren't helping me either when I do actually romp on the gas and the boost hits I already have to shift! I'm not sure what gears would be best, probably the dang 3.27's that I had removed and replaced with these 3.73's. If I was still NA, the 3.73's would be perfect IMO.Hmmm....
I think it will make 350tq 300hp
Also be sure to get a datalog of the event. I wanna we it.
