- Jun 21, 2017
- 143
- 16
- 28
Hi Guys,
Thanks for the information and support along the way...I'll post up some pictures shortly. Around Christmas time I purchased a used V2 HO with a heavy duty race bracket and 3.1/6.75 pullies. I'm just putting the finishing touches on it now and it will be done this weekend....It's booked for Dyno time on Feb 12th for tuning. I switched injectors from 24lbs,190lph fuel pump and 73mm mass air to 42lbs'ers, 95MM PMAS and a Aero 340lph. I was hoping to start up the car to get it on the trailer and to check for any leaks...will this be a problem without a base tune?
Also any guesses on power ? Tuner is thinking 10-11lbs of boost...rest of motor is below.
Rest of mods are -
Factory 5.0 Block, Stock Forged Pistons with High Tension rings, honed bores.
ARP rod , main bolts and head studs
Stock 5.0 oil pump
Balanced bottom end
Comp Cams custom cam 218in/220ex degree .512/.512 lift/114 lobe centres
Ford Motorsports roller lifters
Edelbrock Performer Aluminum heads 1.94/1.60 valves
Chambers reshaped and blended at valve seats
Multiangle valve job
Cut for Felpro wirelock head gaskets
Intake ports matched to Felpro 1250 intake gasket
Exhaust Port walls blended from cnc port opening into runners
Extrude Honed Ported
Comp Cams dual valve springs
Crane HD pushrods
Ford Motorsports Cobra intake manifold
Ford Motorsports 65mm Throttle body
31 Spline HD Axles and HD Aubrun rear end
Rest of mods are -
Stock 5.0 oil pump
Balanced bottom end
Crane HD pushrods
