Not moving as quickly as I had envisioned but I think I’ve accepted I’ll be a few months later than I thought. Better late than never, or early with a build I’m not happy with I guess.
Mounted the 3.5” Holley screen. Not sure if that’s where I’ll want it but going to try it out just as a wideband reading.
Also replaced the “cigarette” lighter with a usb bulkhead so I can now plug my laptop into the console and don’t have to fish for the ECU cable or string anything out.
All the more reason to like the ECU where it ended up, under the passenger seat.
Someone made me some 9” adapter brackets to run stock brakes. I got all the rear brake stuff in, just waiting on axles.
Hoping to order those tomorrow, but I’d be lying if I said I wasn’t a little unsure of my measurements.
Tonight I worked on the trunk a little more. Built a mount to put the compressor under the trunk instead of inside.
And zip tied the trans cooler for an approximate location to build a mount for it as well.
I’m really not sure how to approach building the trunk floor itself. So far I cut out an opening for the fuel tank sump but I’m not sure I like where I’m headed with it.
Or if it will end up a noisy SOB when it’s done.
