You can get it, I replaced mine a few years ago. It's a standard part for Fords of that era.thanks for that information on th ignition,doesnt look to hard.just hope i can order one.
The horn button? It is held on via friction. Just pull it towards you. I don't remember if our steering wheels are keyed. So be sure you reinstall it the same position.
If I am remembering correctly you do not have to remove steering wheel to do ignition switch. It only needs to come off if your replacing the tumbler. You drop the whole column. No need to remove column just remove the 2 large bolts on the brake pedal bracket and it drops enough to get to the switch which is mounted on top of the column about 2 feet away from the steering wheel. There is a rod that runs from tumbler to the switch.
progress report has anyone had this problem. When i turned the key ,the starter sticks on. I noticed the ignition switch seems to be sticky,doesnt spring back from start position to run.havent done it yet, wanted to ask first .should i sprayed some lub in around it or just replace it.if so how hard is it to do and can the right ignition switch be ordered for these cars.thanks
