92-01 Crown vics have Romeo blocks 01+ are windsor blocks. 01+ Crown vic motors are basically the same as the 99+ GT motors with the exception of the intake plenums,TB and air intake.
FYI for everyone. CVPI's are NOT fast. They are not "supped" up, they do not have a special CPU, and they don't have a mustang motor. They are limited to 137mph
The only reason why the CVPI has more hp over the reg vics is due to the duel exhaust. 03 Police interceptor is rated at 239hp which is the same as the Crown victoria HPP (handleing and performance package) which has duel exhaust.
A simple swap of motors from a 99 vic and 99 stang will not work.
#1 on the vics the air intake and battery are on the opposite side as the stang.
#2 To correct problem number one you would have to swap your intake plenums
#3 To make #2 work you would have to have PI heads
Vics didn't have PI heads until 01. I would suggest to try and find a 01+ vic motor and just swap intake plenums.
Take it from a CVPI owner
You can also check
www.CrownVic.net
good luck with your project
