E303 cam installation question
ponsai03
21
I have 2 questions: First. I will be installing my GT40 heads, GT40intake and E303 cam(which I haven't buy) to a stock 5.0 bottom end.
Are there any specifications like the "cam degree" specific for this cam or anything else I should do to avoid "guessing"? I know that PVC is a must but what else?
My second question is: What approx. hp and torque should be there after this H/I/C swap supported by shorty headers, cold air intake, 73mm mass air and 70 mm throttle? I will be using 3.73 or 4.10 gears.
Thanks for your help guys....
When installing an E Cam I would just install it straight up which is just dot to dot on the timing gears. Install a new Timing Gear also.
As for estimated HP, with proper tuning, you will probably see about 250-260 RWHP.
OK. So it will just be like installing a factory cam. No advancing or retarding the cam at all. Sorry to ask but I have never installed an aftermarket cam like the E.
