Msd Distributor install help needed
ballajb64
76
California
I just installed a new msd distributor and my timing is all off, the car will not start. Does anyone know how to tell which spot is spot#1 on the msd cap and how to make sure the motor is at tdc?
  • Sponsors(?)
BlownFiveLiter
have car, will race....wait, it doesn't run
18
88
Chicagoland
The cap should have a number one on it. To make sure you're at TDC, the easiest way would be to rotate the engine by hand until the 0 on the balancer lines up with the pointer. You're either at TDC on the compression stroke, or exhaust stroke that way. If it runs like absolute crap when you put the distributor in and time it, pull it back out, spin the rotor around 180° and stab it back in. Then time it again and see how it runs.
jrichker
StangNet's favorite TOOL
SN Certified Technician
Mar 10, 2000
27,357
2,824
234
74
Dublin GA
lowendmac.com
Putting the distributor back in is fairly simple. Pull #1 sparkplug, put your finger in the sparkplug hole,
crank the engine until you feel compression. Then line up the TDC mark on the balancer with the pointer
on the engine block.
The distributor starts out with the #1 plug wire lined up at about 12:00 with you facing it. Align the rotor
to about 11:00, since it will turn clockwise as it slides into place.
Align the distributor rotor up with the #1 position marked on the cap, slide the distributor down into the block,
(you may have to wiggle the rotor slightly to get the gear to engage) and then note where the rotor is pointing.
If it still lines up with #1 position on the cap, install the clamp and bolt. If not, pull it out and turn 1 tooth forwards
or backwards and try again. Put the #1 spark plug back in and tighten it down, put the clamp on the distributor,
but don't tighten it too much, as you will have to move the distributor to set the timing. Note that if it doesn't
align perfectly with #1 position, you can turn the distributor until it does. The only problem is that if you are too
far one way or the other, you can't turn the distributor enough to get the 10-14 degree optimum timing range.
At this point hook up all the wires, get out the timing light and start the engine. Set the timing where your car
runs best. Don't forget to disconnect the SPOUT jumper connector when you set the timing, and plug it back
in when you finish.
The HO firing order is 1-3-7-2-6-5-4-8.
Non HO firing order is 1-5-4-2-6-3-7-8
Thread starter Similar threads Forum Replies Date
69shocktower Electrical Msd 6al Box And Distributor Install Classic Mustang Specific Tech 1
edgars23 MSD Distributor Install Problems Classic Mustang Specific Tech 8
Zsn95harris Ignition 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
THEUNDERCOATER Msd Distributor Cap Fox 5.0 Mustang Tech 4
Doug Nash SOLD Msd Pro-billet Street Distributor #8477 For 351c, 351m, 400, 429, 460, Classic Mustangs For Sale 2
69shocktower Msd Distributor 69 351w 1965 - 1973 Classic Mustangs -General/Talk- 22
Anaconda Msd Distributor For 5.0 Fox 5.0 Mustang Tech 11
oneslowgt Electrical Where To Buy Msd Parts To Rebuild Distributor? 1994 - 1995 Specific Tech 3
larrym1961 Msd (may Die Suddenly) Pro Billet Distributors. What Are Your Complaints? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 64
C Expired MSD 6AL chip, MSD billet Distributor. Blaster 3 coil. Engine and Power Adder 0
MeanMussy Fs: Msd Distributor Cap Engine and Power Adder 1
ThatBear Msd Distributor And Trick Flow Throttle Body Elbow For 94-95 Engine and Power Adder Parts 3
Brad Compton Msd Pro Billet Distributor (302) Engine and Power Adder 0
C MSD Billet Distributor P/N 85805 351W w/ Edelbrock Vic JR Other Classifieds 0
Justin81 Are MSD Pro Billet Distributors garbage? Fox 5.0 Mustang Tech 26
C Complete intake setup (Fuel Rail,s injectors, MSD distributor, MAF, throttle body and much more) Engine and Power Adder Parts 0
P EFI to Carb/MSD Distributor selection Fox 5.0 Mustang Tech 2
S MSD Billet Distributor for EFI 302, MSD Blaster TFI Coil, MSD Blaster 2 Coil for sale Engine and Power Adder 4
S Mallory Unilite 351W Mechanical Advance Distributor & MSD Blaster 3 Coil Engine and Power Adder 0
Blown331LX MSD Billet Distributor #8479 - SBF Ford 5.0 302/351 - LIKE NEW - $200 Drivetrain Parts 1
SScott 4 MSD Pro Billet Distributor Mag Pickups Drivetrain Parts 0
89-notchback MSD Pro Billet Distributor Ford 302 and mallory 250 fuel pump Engine and Power Adder 0
Tim65GT MSD Distributor cap question Classic Mustang Specific Tech 6
C MSD Pro Billet Distributor Engine and Power Adder Parts 0
6 MSD Pro Billet distributor: 289-302 Engine and Power Adder 0
M Used MSD distributor P/N 85805 w/wires Engine and Power Adder 1
B TFI Msd Distributor dont buy!!!! Fox 5.0 Mustang Tech 8
str8stang036 MSD distributor timming 1994 - 1995 Specific Tech 1
red ink MSD distributor...can i replace PIP? 1994 - 1995 Specific Tech 13
N MSD Billet Distributor Fox 5.0 Mustang Tech 2
DarkoStoj excessive distributor shaft play, msd distributor Fox 5.0 Mustang Tech 2
BStevens What MSD distributor to buy? Fox 5.0 Mustang Tech 1
94GTLaserRC Quetion for those with MSD Distributor. 1994 - 1995 Specific Tech 4
66 Restomod Seating MSD distributor -- sat flush before, now won't... Classic Mustang Specific Tech 2
H MSD has no spark at distributor Fox 5.0 Mustang Tech 13
G MSD distributor Fox 5.0 Mustang Tech 8
OonDeanisS which MSD distributor should i buy? Fox 5.0 Mustang Tech 4
Guero MSD Distributor 1994 - 1995 Specific Tech 9
69clark MSD distributor Overlay MOD! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 6
BlooDReigN Do NOT buy and MSD distributor!!! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 20
KAILUAZ MSD Ready-to-Run distributors? Fox 5.0 Mustang Tech 10
R MSD-Small Base Distributor Classic Mustang Specific Tech 9
H MSD Distributor for 351W Victor Jr intake Classic Mustang Specific Tech 3
Drinknbuddy msd distributor.. Fox 5.0 Mustang Tech 2
BK_CAULEY Distributors 302 HO vs. 351W vs. MSD 351W Fox 5.0 Mustang Tech 5
gruvee87vertgt Which MSD Distributor should I get? What's the difference in Model number? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
R stock TFI module on MSD Distributor? Fox 5.0 Mustang Tech 3
KBCobra95 MSD Distributor? 1994 - 1995 Specific Tech 17
WhiteDevil Problem with MSD Distributor 1994 - 1995 Specific Tech 20
9 Help!! MSD Distributor Fox 5.0 Mustang Tech 5
