Sorry to dig up a old thread but this is the best and most complete write up of AODE to T5 anywhere on the internet. I have been searching ages for all this info and found lots of other stuff for AOD to T5 but nothing nearly this detailed for AODE specifically.
My big question i've been trying to find the answer for: Did you re-use your AODE tranny harness or did you get a used T5 harness? I know they are different, but I think I only need to use the reverse light switch and the VSS sensor, and if i had a pinout of each one, I could re-pin my AODE or splice it easily to make it work.
I've been searching for a T5 harness for a long time with no success, its the only piece im missing for the swap, so a re-pin seems to be my only option which is fine, just need to confirm all the info to do it. Anyway...thanks for all this info and if you could just explain how you wired it that would be awesome.
