Nice to see you working on it again Adam, keep the updates coming!
Thanks man comments like this keep me going!
GOOD NEWS FOR TODAY!
Me and chris put the wheels on the car and pushed it out so we could sweep out the garage and enjoy the nice sunny day.
First thing first we needed to play with the ditsy and see if it ran better... so we noticed that it was hitting the lower intake. SO we pulled the ditsy... and restabbed it... Brought #1 to TDC on intake moved the ditsy about 30*... There goes my nicely cut wires
VIDEOS!!!!:
MVI_0359.mp4 video by blindfoldedhope - Photobucket
MVI_0360.mp4 video by blindfoldedhope - Photobucket
The temp was getting up to 225 ish and the top hose was not getting flow... So we went and got some more distilled water because it was low... We picked up gas too and dumped in some injector cleaner... we were on e and didnt wanna suck up any old gunk in the tank
It seemed to hang around 220-230 ish so we cut it out.... might be a heat issue
There was also some intake back fire every once in awhile... so it defiantly needs some work
Brake lines are not leaking... But are pure MUSH need to bleed again... but we both ran out of leg power:
So then we moved on to gauge install:
All went well and we calibrated the wideband
However at idle i was at 17.7 AFR.... little lean... We need a timing light to correctly set base timing... we threw ours out when we were cleaning...
On that note out of light, seat back in and in she goes... This time we drove it in...
Test drives to come.... we tightned up some exhaust stuff... the H pipe needs work... leaking on the ball connectors in the back... however everything sits low so we might make a new trans cross member. But this will do till now... For the crossmember and exhaust we will be putting it on the lift at chris' work.
