okay, im looking for a new set of rocker arms for my e7's. right now theres a set of aftermarket svo 1.7 ratio rockers on it, which are like, 13 years old. so i was looking thru summit and found these
***FMS-M6564A50***
"Ford: 1978 and later 302/351W, with OEM and GT-40 heads, 1.70:1 ratio, bolt-on, roller rocker arms
When you're looking to increase power, look no further than this set of roller rocker arms. Features include precision machined construction from 2024 high tensile aircraft aluminum, high strength trunnions supported by needle bearings, and grade 8 adjusting nuts. They reduce parasidic losses from friction and increase high RPM stability. This set will fit all stock production cast iron heads with hydraulic non-adjustable valve train. Includes pedestal inserts and bolts.
Sold as a set of 16."
do those sound like they will work? i have an 86 with stock cast iron e7 heads. thanks for the info
b.j.
***FMS-M6564A50***
b.j.
