I deleted the A/C, and the 2 idler pullies on the passenger side of the timing chain cover. I took the pulley off the tensioner and installed a ribbed pulley. Then ended up using a 69" belt. Here's a pic.
Wow, that cleans up the engine bay a little. Do you live in a cold climate or do you have another car? Thanks for the info on belt size, it may help someone out in the future.
sorry to ressurrect this thread, but curious to see if anyone knew where to get a ribbed pully for the tensioner. i've had my car for 3 years and only used the AC twice, always used heat for defrosting so i think this would be perfect.
Well you have used your AC more then you think. When the HVAC controls are on AC, MAX AC, MIX, or DEFROST, the AC compressor is on. They run it to remove the moisture from the air. The only time it isn't on is FLOOR, VENT, and OFF.
heh thats all i really use, though the occasional defroster. in the summer though i dont think i will need the defrost, and like i said never use AC for cooling purposes
but nobody knows where to pickup a ribbed pully for the tensioner?
