I just need a welder to weld my O2 sensor bungs for my EFI conversion, and a new export brace (custom made). Later down the line I will need it for the cowl vent problem, front D/S floorpan section, and the radiator support. Maybe also for the p/s door panel. I don't know anything about welding, I have a friend who can weld in the O2 sensor bungs, and I can buy scrap sheetmetal and practice with it before tackeling the other things.
I know this isn't the best welder, but I haven't much cash to work with. Plus I'm not going to use it but maybe 3-4 times a year... if that.
For use with or without gas. Comes with welding torch, tip, grounding cord with clamp, brush/hammer, hand held welding mask and manual.
Factory reconditioned, factory perfect; Input: 230V, 60 Hz, single phase; Welding current range: 30-120 amps; Duty cycle: 15% @ 115 amps; Draws 15 amps @ 230V; Max. open circuit voltage: 36V; Weldable wires: .023", .030", and .035 steel or stainless steel; .030" and .035" aluminum; .030" flux core
