Quick question, my horn switch is shot, and none of the auto parts store have a new one. Am I gonna have to find one in a junkyard or can I get one online? Its an 89 so no airbag either, thanks
the problem is most likely in the cigar lighter circuit
FIXED!! it was the cigar outlet. Why would that be an issue? Its brand new. I just disconnected it but still need it. What can I do?
The rubber foam usually deterioates over time and that is what makes the horn switch fail. Take it apart and replace the foam with some from packaging material. A little creative engineering may be required, but you can do it.
Moses, I had the same problem all the time. Horn stopped working, no cruise control and the problem was in the cigarette outlet. Found a little screw in it that was blowing fuses all the time
Check closely for anything grounding somewhere. I couldn't believe it was a stupid little screw causing my problems.
Hmm I see what you mean with the foam waisting away, how thick should the new foam be, and do I just cut holes in it for all the little bubbles on the plate where they contact?
hey there, where can you get replacement fuses for the horn circuit?
