okay so I have everything set up and motor is running HOT. Here is what I've got that makes a diff in cooling:
no radical motor just warmed up stock block (cam, al heads, 12 deg timing)
+30% water pump
March underdrives (crank & water)
Taurus 3.8 2spd fan (wired to high)
DCC fk35
3 row radiator - not aluminum
180 stant t-stat
Heres how I had the controller setup:
-hooked to constant power for cooling after shutoff
-temp probe is in fins at middle of lower rad. hose
-jumpers are at stock 180 setting
temp guage at idle is half way...with mechanical fan it was just above 1/4
driving around block <5 miles guage went up to 3/4 or a shy more babying it the whole way.
What do you guys have your controller settings at if you have similar setup?
+30% water pump
DCC fk35
180 stant t-stat
