Makdaddymac
well i got the part today and want to install it,on tuesday.i'll see/let you know how it goes...hopefully this is my problem,cause i woul like to start seeing how many miles to the gallon and tank i get in this thing??!?!?
Steve and I have gotten the instrument panel out of the car and down to having taken the gear out for the odometer (half the teeth are missing!).
Anyway, we never thought about what type of grease to use.
I hope someone can reply soon, as my car is nonfunctional until we figure out what type grease to use.
Thanks!
It's Sunday, July 8.....
sue
So when I go to buy a gear at odometergears.com, I can buy a main drive gear and a worm gear. Which do I get and whats the difference?
The main is what goes usually. I orderd the main hear recently.
Great detailed write-up.
Here is a question for you.
I currently have a speedo that does not work in my 94GT. Bounces around all over the place... The odometer works great however.
I replaced the speedo gear which did not help and will try a replacement VSS. If it turns out that the speedo itself is faulty, can I replace the speedo itself without replacing the cluster?
This is absolutely the most complete thread I've seen posted any where, great job! Would you happen to have a thread for replacing a PCV on a 94 5.0? Again, great job!
