At WOT how far open is the Throttle plate supposed to be? I've had a rich condition for a while and just trying to knock everything I can think of off the list. Thanks
HISSIN50 said:I know I'm real tired, but wouldnt the angle from closed throttle to WOT (or parallel with the air stream) be 90*. I think so.
So it's opening about halfway - is that right?
WHile doing this, you can see what your TPS is reading - it might be interesting to see what it maxes out at.
In my experience, the range of throttle blade opening varies. Unless someone really paid attention during the install and adjusted things, it's seldom parallel to air flow. But it should open 75-95% of its theoretical travel (I tried to say that without using degrees).
Good luck.
