mikethebike
Even if the piston area is completely off, as long as the percentage of braking front to rear is about the same shouldn't it still work ? I havn't really educated myself as to how the ABS brain flows the fluid. Does it only send a certain amount ? I thought it pushed fluid unit it saw a certain reading from the censors and then backed off then repeated.
In it's most basic form an ABS counts magnetic pulses and when they drop below a certain % of road speed the ABS opens a pressure relief valve. The better systems are 4 channel and can open/close about 10 times a second or faster.
