Im here.
What a jug fck.
It took till about 10am to get the torque troll installed. I checked his up angle..seems that he is at an actual 4 degrees.
( thats what I originally wanted).
I had to go into work on my way out..The rear tires were literally jumping off the pavement at 80MPH.
The reason for having to go into work added another hour and a half to my departure..and once on the way out..the bouncing tires had me going south 6 miles, and turning around, swearing that the tire store that mounted them on Sunday either didn't balance the tires properly, or bent a wheel while doing so.
BUT....by the time I get back to the exit,..the tires are no longer jumping, and have smoothed out considerably.
These tires have "flat spotted" and just need to be driven to cool the fck out.
So....I turn around, and head south...again....Its 12pm.
The tires would oscillate between running smooth, and out of nowhere acting like its gonna fall the fck off.
THE WHOLE WAY HERE.
The diag is a bad wheel bearing too.
No matter...I'm putting C Clip eliminators on it, and the recommended
@revhead347 Detroit differential upgrade during the upcoming cold assed months.
There is an exhaust leak that pollutes the interior..you have to leave the window down..and you still smell it. Its the exhaust manifold...the thing has been leaking since day one..it is one more thing that I can fix that will just make more power when its done..
Who here can fix a header leak, and pick up anything other than reduced noise, and no more exhaust stink?
I get 150 miles in...I stop for gas..( the things getting like 20+ mpg)..
NO start..Slow crank..like the battery is dying..( WTF should I expect? Its only a 7 year old Optima red top)
If not for my little Chinee Amazon jump box..
I'd still be sitting there, asking for a jump.
Fortunately...I had the wherewithal to bring that thing...And once hooked up..
It Started right up.
The car itself ran perfectly up until the time it got into Fla..Then it decided it to start running really sketchy at idle..By the time I got here..it was all I could do to keep it from dying at idle.
Tomorrow, im turning the Idle screw to speed up the engine.
Then...Im cleaning the 50 bazillion bugs off of it for exactly $1.25.
AND sitting in a chair behind the monster..
